Alignment ?
Wondering if the spacers behind the control arms are correct. They came with truck but it seems like tire is "cambered out" too much. Thoughts?
Never Ending Projects
Re: Alignment ?
Build the truck, get all the weight on it and then get the alignment done. You can't do it just mocking the frame up. As you add weight, the suspension will compress and change your alignment. You're wasting your time doing it before it really is ready and yes, there are spacers used.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Alignment ?
Yes use them i had 12 shims too. Put everything together went to the alignment shop. Thay only used 5 shims total very nice job thay did.
#4 | |
Re: Alignment ?
