Old 10-26-2003, 07:39 PM   #1
71Rat
ran out of money
71Rat's Avatar
need pic of auto brake assem.
Hello everyone i am in need a pic of an auto brake assembly. I ordered one from Truck Shop but I think they are trying to screw me by taking a stick assembly and removing the clutch peddle. I have a stick now and am converting the truck to an auto. If you can post a pic ASAP it would be great so i can deal with the truck shop and get the right peddle set up.
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 10-27-2003, 11:38 AM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
UUMM, are you talking about the whole pedal assembly, tower and all? If so they are the same for automatic and standard. You can slide a clutch pedal into an auto pedal assembly, the auto is the same thing just with the pedal removed. So why did you buy one when all you have to do is slide the clutch pedal out of the tower?? You could return it and get your money back to use on something else, and just remove the clutch pedal and use the same tower for the automatic.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is online now   Reply With Quote
Old 10-27-2003, 06:46 PM   #3
71Rat
ran out of money
71Rat's Avatar
I thought that the auto peddle arm was bent twords the drivers door more then a stick. and isn't the peddle shape different also? i am not as used to the differences of the peddles in this year truck as i am in like an 80's truck.... thanks for the input looks like i might be sending it back
Old 10-27-2003, 07:14 PM   #4
Firefighter
Nope and nope to the questions. The pedal is in the same position in standard and automatics,(I have both) and the brake pedal touches the side of my foot while it is on the gas pedal in both trucks. And the brake pedal is the same size as the clutch pedal, Only on '73 and up is the pedal bigger. I hope this clears up things for ya!! Glad to be of assistance!!!
Yellville, Ar. USA
Old 10-27-2003, 07:29 PM   #5
71Rat
ran out of money
71Rat's Avatar
Thank you very much...... wish i knew this a little while ago.... ohh well, thanks again
Old 10-27-2003, 08:37 PM   #6
Firefighter
Anytime!!!!!
Yellville, Ar. USA
