Old 08-20-2017, 09:18 PM   #1
44SAA
Rubber Vacuum Hoses/ Replacement
The rubber vacuum and emissions hoses on my '80 C20 are factory, and need replacing. 2 questions:
1) are these hoses the same i.d?
2) is there a SAE rating I need to look for?
44SAA is offline   Reply With Quote
Old 08-20-2017, 09:32 PM   #2
44SAA
Re: Rubber Vacuum Hoses/ Replacement
Pics of the rotted rats nest I'm replacing. Pic of description I can't quite make out on hose
Old 08-20-2017, 09:56 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
Looks like the snake pit under my hood
Malo83 is offline   Reply With Quote
Old 08-20-2017, 10:15 PM   #4
44SAA
Yea, it is pretty ridiculous. I thought hard about ripping that trash out, but I'm not confident about what I can delete. As a result, I'm gonna double down and redo it. Oh, I did delete the EGR valve. After removing the pass valve cover in 104F I told myself I would never remove or install again with the EGR blocking access. The same GM engineer that decided to mount the trans pan above the cross member must have decided where to place that EGR.
