Old 08-21-2017, 06:59 PM   #1
Bisblue
Bisblue's Avatar
292 dipstick length and capacity
Hey folks bought this 72 and have been driving it lots. The dip stick is too long, so I was running low on oil and the pressure dropped a touch.
I changed the oil and put 5 quarts in it pressure jumped back up. Should I mark it there or does the 292 take 6 quarts?
Thanks folks
Bisblue is offline   Reply With Quote
Old 08-21-2017, 08:45 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 292 dipstick length and capacity
I changed the oil and put 5 quarts in it pressure jumped back up. Should I mark it there or does it take 6 quarts?
Thanks folks
Might depend on what engine you have. The Chevy 350's take 5 quarts with a filter change. I don't know about the GMC engines....
LockDoc
Leon
Old 08-22-2017, 05:59 AM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
The 292 takes six quarts.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 08-22-2017, 06:06 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
292 will take 6 quarts if you include a new long-style oil filter like AC PF-35, Wix 51060.
I use 6 at oil changes.
Forget any V8 capacities, the L6 is a different animal. The 292 has a deeper oilpan than the 230 and 250, easily a quart more.
How is your dipstick too long? Not OEM? Finding a real 292 dipstick may be hard, half a century later, but they're out there.
Old 08-22-2017, 08:30 AM   #5
LockDoc
LockDoc's Avatar
I see you edited your post and added the 292. I wish you had stated it was a 292 before I posted my reply. That is why it is important to list all information on a truck when you ask a question.
LockDoc
Leon
Old 08-22-2017, 10:13 AM   #6
Bisblue
Bisblue's Avatar
Apologies I put it in the title but forgot to put it in the post itself.
Dipstick is way too long, who knows maybe the tube got chopped down at some point. I'll add another quart and then I'll mark it so I've got a mark at 6 quarts and the 5 quart mark I put on earlier for my high and low. I cut the extra length off so it's not contacting anything in the bottom of the pan.
Thanks folks.
