Old 08-22-2017, 08:38 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
Quick c20 disc brake conversion question
i looked on here but cant quite find my answer
my 1970 gmc c25 has drums all the way around
i have some front (disc) spindles that i plan to use.
looking on line they sell brake power brake booster kits
and master cylinder kits (everything to do the job)
my question, my truck has power brakes already from the factory correct?
aside from a disc Brake Proportioning Valve.
doesn't the truck have everything on it already to convert?
or am i missing somthing. (all the new brake stuff isnt needed is it?)
i plan on doing a full hydroboost (4 wheel disc) system in the future with the wilwood master.
but heck this could be a cheaper option for the time being.
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 08-22-2017, 10:06 PM   #2
wbc409
Re: Quick c20 disc brake conversion question
Using just the spindles you need to make sure that there are ball joints available. They need to be correct diameter and taper. You will also need to use the correct outer ball joint.
I forgot the website, but there is a guy that makes disc brake conversions for the Eaton rear axle. From what I remember they were very reasonably priced.
wbc409 is offline   Reply With Quote
Old 08-22-2017, 10:23 PM   #3
nrb's70gmc
nrb's70gmc's Avatar
thanks for that info, my truck has a dana60 (super easy to convert) and many kits
