Old 08-22-2017, 09:30 PM   #1
mehoff400
brake lightrs
needing a little help... the previous owner rewired my truck with a kwik wiring and the rear turn signals don't work correctly as they both flash at the same time and i think i chased it down why. he splice the 2 wire brake light power and brake light switch together and ran that to the tail lights. from the research i have done it looks like it needs 1 power to the switch then 1 wire to the turn switch.
and then i am guessing it would get brake light through the turn signal wires?
if this is correct what wire would i tie this into on the turn signal switch?
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 08-22-2017, 10:05 PM   #2
mehoff400
Re: brake lightrs
nevermind....... i found the wire it needed to be connected to in the turn signal switch (white). once i hooked that up and removed the power wire going from the switch to each tail light it magically worked.
My truck
