Old 08-22-2017, 10:48 PM   #1
JCs72C10
Brake Shoes Issue/Question
I have two 12 bolt diffs. One has 2" shoes, the other 3". I'm curious if I can swap the 2"shoes and drums with the 3".
The reason being is the the diff with the 2"is no good, save the shoes. I just rebuilt the diff with 3", but have not yet replaced the shoes due to my curiosity.
JCs72C10 is offline   Reply With Quote
Old 08-22-2017, 10:52 PM   #2
sweetk30
sweetk30's Avatar
Re: Brake Shoes Issue/Question
backing plate has to be swapped also .
the depth of it is diffrent for the width change .
when i swapped from std drum brake size to the bigger option brakes in the 12bolt on my 2wd i had to get the used backing plates to match . otherwise bolt on and go .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
