08-23-2017, 01:33 AM | #1 |
Looking for a model suggestion for my first resto project
Hi. I'm new to the board and I've come to see if the good people here can help me narrow down a pickup truck model to focus on as a rebuild project. Lately I've been learning some about the 60-66 trucks and decided this is the style I'd like to focus on. But before I get into the project details, a little about myself..
I'm a self taught reasonably competent mechanic that's been doing all my car maintenance (except deep engine, clutch or trans work) for the last 20 years or so. I have some body (bondo, primer and wet sanding) experience but haven't done much in the way of dent removal or panel replacement. Although I don't have a lot of welding experience mig welding comes naturally enough. If I don't know how to do something I ask questions, and with good advice can usually get the job done. So, what I'm looking for.. Basically I'd like to find a good, what I'd call 'atomic era' truck of early to mid 60s (or 50s possibly) to get into good shape and use as a work truck. After getting it right mechanically and with a great body and paint job, it would be used primarily to travel to bid on residential and commercial painting jobs. Basically it would be used as a selling point to illustrate the quality of work we do as a company. Requirements for the truck is to be gas efficient, which would probably mean an in-line 6 engine paired with an auto trans w/ overdrive. And to be comfortable and drivable... meaning power steering, disc brakes and a/c. It would need to handle stop and go city driving, as well as be able to do short hops of 65 mph safely on the interstate. Hauling duties would be minimal. The model I've gotten to know best so far are the 60-66 Chevy c10s, although I'm open to just about anything including the same era f100s or Internationals, or I even sort of like the 50s Chevy Advance Design models. So that's about it. You guys have an opinion on what model trucks of this era would be a good candidate for what I'm looking to do? |
08-23-2017, 06:47 AM | #2 |
Re: Looking for a model suggestion for my first resto project
They are my favorite, so thats my vote. Hard to beat the style and I am partial to the 64 to 66 cabs. Got my first one more than 40 years ago and always come back to them.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
08-23-2017, 08:02 AM | #3 |
But Found Her 25yrs Later!
64-66 will be the easiest of the 60-66. Then 63, then 62, then 60-61.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-23-2017, 09:50 AM | #4 |
Bradley,
Although I'm partial to the 60-66, a 67-72 might be a little easier for a beginner because parts are SUPER common, and '71 was the first year with factory front disc brakes. |
08-23-2017, 12:43 PM | #5 |
Never Ending Projects
Oh, and if you want efficient, don't really waste your time on a inline 6 engine. These trucks are heavy and the 6 isn't really going to get you better mileage than a mild V8 with an overdrive. Part are harder to find and can be a little more expensive for the 6 than the common SBC V8.
Biggest advantage to using the 64-66 is they share the most common parts and have the most reproduced of the 60-66 era. If you go with the '59 or earlier, you have a solid front axle which is going to ride much worst than the IFS of '60 and later.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-23-2017, 09:58 PM | #6 |
64-66 SWB with a SB and 700R. Add PS/PB and A/C.
But... what's your budget? |
08-23-2017, 11:32 PM | #7 |
60-66 Nut
I think the best choice for a fuel efficient engine and trans will be a 4.8 OR 5.3 LS engine. With the correct rear gearing and a good tune you should be able to achieve MPG in the low to mid 20's.
08-27-2017, 01:46 PM | #8 |
I have a 66 but for you maybe the 67 to 72.
08-27-2017, 02:12 PM | #9 |
Here's my list, and reasons:
'60-'62 is more expensive, because they have the torsion-bar front suspension, X-member frame and hydraulic clutch. All of these things combine to make parts for a rebuild and upgrade more expensive. The parts ARE out there, but you'll pay a higher price than later trucks. '60-'63 has the wrap-around front windshield, which I REALLY like. Windshield is much more expensive than the later trucks, as are the vent windows. They have the drop-out center section rear axle assembly, which is expensive to rebuild, and limits your gear choices VERY much. An optional Dana 44 rear axle was available for these years, and while they're a fantastic rear end, have about 20 different gear ratios available, and are still used in Fords and Jeeps so posi units are cheap, they're very rare to find in the '60-62 truck mounting points. 1963 has easy and inexpensive mechanical clutch linkage, essentially the same frame as later trucks, and is in my opinion the best of both worlds: the later style frame is easily upgradeable with more modern front suspension, and it has the cool wrap-around windshield. The rear axle is a bit of a one-year-only deal, but not a deal-breaker. 1960-61 trucks, if you like the big Double Bubble hoods, those are expensive. The grilles for 60-62 are also more expensive then their '63-up counterparts. Both to buy, and then to rebuild since for '60-'61 you've got to buy twice the number of lights and adjuster hardware. Factory full-instrument clusters are more expensive for the '60-'63 truck as well. '64-'66 are the easiest and cheapest chassis/suspensions to upgrade of the era, with factory junkyard parts from later vehicles, and after-market parts. The windshields are much cheaper than the wrap-around earlier ones. Full-instrument gauge clusters are cheaper if you want to upgrade. Just about EVERYTHING is available reproduction for them, while there's a lot of holes in the '60-'62 offerings. All these trucks are still found in junkyards, but it's not like it was 10 years ago. Factory options like Power Steering and A/C are nearly non-existent, and expensive when you find them, power brakes are rare too, but the aftermarket has that covered. '67-'72 trucks are very plentiful, everything is available for them, they had more factory options like A/C, Power Steering, Power Brakes, factory sway bars, disc brakes on the later ones, they're plentiful in junk yards if you like junk yard crawling (I do), and the aftermarket is choked with everything you'd need. And it's usually cheaper than the '60-'66 stuff. Me? I like the '60-'63 trucks, and that's what I've got (Suburban and K10). If I was starting from scratch like you are, I'd go for the '63-'66 trucks. If I was strictly going by cost, it'd be '64-'66 trucks for the last of the Atomic Era, but '67-'72 is better strictly from an accounting bottom-line perspective. The '55-'59 trucks look great, but they're about twice as expensive to build as the '60-'66 trucks, starting with the purchase price and going from there. I've got a friend who loves them, and he keeps buying starting points... a ROUGH, non-running starting point is $3-4K, while I can buy complete, driving '60-'66 trucks all day long for that price. And then buying the parts needed to get the '55-'59 trucks back on the road is much more expensive. For cabs that aren't as roomy as the '60-'66. For powering yours: Crate 350, 290-350hp is all you'll need, they're cheap, reliable and have a warranty. Brackets, intakes, power steering conversions, and everything else you'll need is a lot cheaper than building and dressing an Inline 6. Overdrive trans, with 3.55 or 3.42 gears in the back will honk you down the road at 75mph all day every day. Get a good radiator, a factory fan shroud, and the biggest fan you can fit in the opening. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
08-27-2017, 09:51 PM | #10 |
I own a '51 pickup and a '64 suburban (project).
I would recommend a 64-66 for what you want. The '64 has been much easier and less expensive to upgrade the suspension and brakes. |
08-30-2017, 01:44 AM | #11 |
First thanks everybody so much for all the good info. This is exactly what I'm needing with my steep learning curve and everything right now.
Yes it seems the more I learn the more I'm leaning toward the mid 60s c10s b/c they just seem easier and possibly a little less expensive to tackle (among the early to mid 60s c10s that is). I know the next era trucks 1967- seem to have more of the creature comfort options I'm wanting, it's just that the styling has changed too much for me in the newer body styles. And Brad54 thanks a ton for all the info. I really do like those wrap around windshields too and based on what you're saying I should prob go for a '63 if I want that style. Considering the upgrades I'm wanting to do what type of issues would a '63 present vs. trying to achieve the same thing with a '64-66? questions 1- What's surprised me in what I've learned so far is that I would prob get equal if not better gas mileage w/ a V8 rather than an inline 6. Considering the condition these original engines are likely to be in, would it be better/cheaper to drop a new engine and tranny both in, or go with the V8 that comes in whatever model I get and then try to pair an auto trans with it? 2- I would guess when saying SBC V8, the sbc stands for small block chevy instead of single barrel carburetor? DPowers... Sorry I'm not sure about the abbreviations. When saying '64-66 SWB with a SB and 700R...what does SWB and SB stand for? |
08-30-2017, 08:48 AM | #12 |
SBC = Small Block Chevy
SB = Short Bed SWB = Short Wheel Base (aka Short Bed) If you're justifying a new engine with fuel savings, it will take thousands of miles to repay it. You shouldn't have much of an issue pairing the existing v8 to a 700r4, and that will get you the overdrive you want. Alternately you could get a little more power out of the v8 by freshening it up, and give yourself a slightly higher rear-end gear, which is a pretty inexpensive way to go and also keeps things pretty easy mechanically. I think one key you should focus on is to not get too ambitious in your projects until your experience level goes up. One of the most common ways that projects die is the owner finds himself out of his depth and loses interest. When you plan something keep in mind that it WILL be more complicated and expensive than you anticipate. B |
08-30-2017, 09:49 AM | #13 |
A couple threads that might interest you :
. http://67-72chevytrucks.com/vboard/s...d.php?t=744935 . http://67-72chevytrucks.com/vboard/s...d.php?t=484935 .
08-30-2017, 10:39 AM | #14 |
...just another truck junkie..
Go '63. Nothing beats the look of the knee-knocker cab. Of course I am a bit biased....
Mike "Bear" Shea |
08-30-2017, 10:56 AM | #15 |
I kinda like this truck, it's been hard for me not to go buy it.
https://nashville.craigslist.org/cto...261084119.html You may not want a C30, but this thing has potential... Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
08-30-2017, 07:34 PM | #16 |
It sounds like you want a nice frame off restore type vehicle which can take years and/or cubic dollars--as asked, what's the budget? Who will do the work? Most people find that once its apart, they want little to do with the project and scrap or sell.
A few possibilities and my truck preferences... 55-57 looks like a 55 Chevy 64-66 avoids the odd frame/suspension issues 71-72 factory disk brakes None of these are going to get great mileage since they're heavy and have the aerodynamics of a brick. An LS and OD trans will help, but you may need to swap rear gears to match the OD and power/RPM. |
09-01-2017, 09:23 PM | #17 | |
A point of interest: the difference in hp between the 4.8 and the 5.3 is only something like only 10 ponies! Then, I might swap my finished '66 to you for yours! Good luck, Sam |
09-02-2017, 01:18 AM | #18 |
I got 15-17mpg pretty reliably with my '61 suburban.
Crate 350 290hp, 3.42 rear gear, tall tires, 4spd OD manual trans with .72:1 OD. LS engines are awesome, but fuel injection and computers are expensive, and they'll require fabricated engine mounts, electric fan, electric fuel pump, return line to the tank, etc etc. A carb'd small block is still the cheapest and simplest way to go. For the OP, if you dig the wrap-around windshield, the '63 is the way to go. Front suspension will swap with later trucks, as a bolt-in. 5-lug conversion if you want, disk brakes, sway bars, etc etc. Rear axle is fine.
09-02-2017, 04:35 PM | #19 | |
Sam |
