Old 08-23-2017, 03:42 AM   #1
jkk
jkk's Avatar
Wheel Spacers for rear
Hey Guys
Anybody running rear wheel spacers I have 8" TTII's on the back looking to bring them out to the edge of the bed.
1'' / 1 1/2' / or 2" good idea or bad who sells quality spacers?
Thanks for any info
jkk is offline   Reply With Quote
Old 08-23-2017, 02:38 PM   #2
PunishedC10
Re: Wheel Spacers for rear
The best to get would be BORA billet wheel adapters. You can get them with matching bolt patterns or two different patterns like if you wanted to run a wheel that has a different pattern then what your truck has. They are hub centric as well
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 08-23-2017, 02:41 PM   #3
PunishedC10
I'll add that you will want to stay away from the traditional wheel spacers that simply slide over your wheel studs and cover the threads and are non hub centric. You will end up with the wheel falling off after the studs are broken.
The picture is some for an F-150. But you can see that they bolt to your truck and your wheel bolts to the adapter/spacer. These are completely safe if torqued properly.
Old 08-23-2017, 02:55 PM   #4
LuvNLife
LuvNLife's Avatar
These are the folks I bought my current spacers from:
http://www.ezaccessory.com/Wheel_Ada...5500-5500p.htm You just need to choose your thickness.
One thing to watch is be sure the studs are 1/2X12, not metric; you'll end up with having to buy 2 different sets of lug nuts otherwise.
LuvNLife is offline   Reply With Quote
Old 08-24-2017, 12:40 PM   #5
Bobzilla75
I use these with my 17x8.5
https://www.amazon.com/4pc-Thick-HUB...+WHEEL+SPACERS
Bobzilla75 is offline   Reply With Quote
Old 02-11-2018, 01:31 PM   #6
BHTH
I haven't been able to find anybody besides these guys that make spacers for 4x4 squares. What are your impressions of yours? I'm a little leery, but I'll be honest, my K5 will never be off-road or haul/tow.
If anybody else has used anybody else on a 4X4 please chime in.
BHTH is offline   Reply With Quote
