1966 C10 Fuel Line Size
Hello,
now I make/ install the new Fuel Line with the Fuel Filters, Fuel Pump, Gas Tank und the Carb (Edelbrock Performer 500cfm). I would like to put a steel hard line in 5/16 from the Gas Tank to the First Fuel Filter Canister Style with 3/8 NPT inlet and outlet under the Cab. From the Filter with 5/16 Hard Line to the Fuel Pump (3/8 NPT inlet/ outlet). From the Fuel Pump with a 5/16 Hard Line to the second Fuel Filter and to the Carb with 3/8 Inlet. Now my Question. Is it better to use compleate 3/8 Steel line from the Gas Tank and not 5/16 ? The Problem ist, that the Tank Sendig unit have a 5/16 Line and thread. What is the best option with the Edelbrock Performer 500cfm. The old Carb was a 2 Barrel. Thank you all verry verry much. Greatings from Germany Nils |
Re: 1966 C10 Fuel Line Size
By the way. The Engine is a 283 c.i. V8
![]() Join Date: Jan 2011
5/16 is fine. Also that carb needs a fuel pressure regulator as they dont like much more than 4 psi. Some will take 5 but my last two eldelbrocks like 4 better.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
