door drop glass alignment 49' single piece glass
hi all, i fitted new drop glass seals etc to a one piece door. the glass is rotated forward and is not sealing correctly in the frame... i see there are some slots in the winder mech mountings on the door do they adjust this? whats the process to adjust it..
picture in comment below Last edited by sqweaka; 08-23-2017 at 02:02 PM. |
Post Whore
![]() ![]() Join Date: May 2015
Re: door drop glass alignment 49' single piece glass
you'll need to use something other than photobucket to post pics..
is there a way to just use a smart phone?
Post Whore
don't know...this works though...http://67-72chevytrucks.com/vboard/s...sting+pictures
picture of glass in frame
I think the adjustment instructions are in the factory service manual but I am at work until 7:30 PM pacific time. Maybe someone else can dig it out
On posting photos if you click on the "go advanced" Icon then click on the paper clip to the right of the happy face on the top row the attachments link comes up where you can post attachments/photos and is reasonably self explanatory.
There is a channel that is bolted to the door that a little wheel off the end of an arm of the regulator runs back and forth on. That channel needs to be rocked one way or the other. I don't remember exactly what way but if you loosen it and rock it you will see the glass rocking as well.
That is all there is to it. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Crap, now I am looking at this photo I found and that channel doesn't move, I could swear it did. That is super basic stuff, check and see if yours does, I could swear it did.
Brian ![]()
thanks your photo isn't showing brian!
Hollister Road Co.
One or all of the following at happening.
Roller is shot and or not there in the front of the regulator The regulator needs to be replaced. Picture 42 shows the screws you have access to https://www.hollisterroad.com/Door-Window.php loosen them all and crank up the window and get it where you want it then tighten the screws. if it stays in position your good, if it drops back you have a mechanical issue listed above |
#11 | |
![]() Brian
