Hey guys new to the forum as a member.but been reading threads for a few years. Recently picked up a 58 big window fleet,. Guna pull the frame in the shop over the winter and get my front and rear suspension Fab'd up,. I read sum older thread from around2008 to 2011 but I know the industry changes. Looking to lay this bad boy out on the ground. Just looking for pros and cons of a few companies. Scott's hotrods super slam, porterbuilts drop member and fat man fabs wide ride,No limit engineering. Looking to be low as I can go with 22" steelies.,. Pretty much I can't decide which company I'm gunna go with haha. Help me out guys. Thank you in advance. Pics are definitely welcome
Re: Ifs and 4 link for bagged 58 apache fleet
Any one with any suggestions? Which front ifs setup is lower or pros and cons of any company. Lower the better.
Lay it out, no doubt Porterbuilt. I can't recommend Scott's, my dad did one on his car (slammed air ride), couldn't make it work correctly. He ended up cutting it off, throwing it in the trash, and buying a morrison clip.
Porterbuilt pros: It works, and will lay the rockers on the ground. Cons: you have to cut off frame rails. If you want to keep the stock frame rails, I wouldn't know which IFS to pick. |
