Is this factory correct paint?
I'm looking at buying a 1972 Cheyenne Super and the paint is throwing me for a bit of a loop. I thought on trucks with upper and lower moldings, the white stripe should be situated in the middle of the moldings?
I thought white bottoms only came on trucks with only lower moldings. It's a Canadian truck and it has been repainted. Picture here: http://imgur.com/a/iwW9l |
![]() Join Date: Aug 2013
Re: Is this factory correct paint?
Not 71-72 factory correct. It should be as you stated. That is 69-70 correct.
You probably should look closer at truck/spid/vin. Etc. etc. to make sure you know what you are getting |
#3 | |
It was a 307 2 bbl truck and a past owner changed the intake and carb so it could run a 4bbl. I previously thought all 72 Cheyenne Supers were 350/4bbl trucks. Seemed like an interesting combination. Other than that and the paint, everything seems correct and original. The VIN and original build sheet for the truck all seem correct. |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Subourbans didn't come with upper trim so the lower and top were the trim color through 72. The pick ups 71 and 72 had the middle stripe on the deluxe two tones. The standard two tone was trim color on the roof.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man Last edited by Ol Blue K20; 08-23-2017 at 08:49 PM. Reason: add to message |
#6 | |
Roadtrip!
![]() Join Date: Feb 2003
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#7 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
