Old 10-26-2003, 10:12 PM   #1
orange72350
orange72350's Avatar
Tranny Cooler Lines
When i yanked the engine and tranny outta my truck, i sorta banged up my tranny cooler lines. They are screwed, so i need new ones. Its a th350. Can u buy the lines already fabbed up, or do u have to buy fittings and build your own? my local parts store cant find them. does anyone know where they can be found, and what they will cost?
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 10-26-2003, 10:33 PM   #2
cableguy0
you just gotta get regular steel line and bend it to fit not that hard just dont try to do any sharp bends because you will kink the line
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-26-2003, 10:34 PM   #3
Adam12
I hate trannys
Adam12's Avatar
can you run rubberlines for this? or steel braded rubber line? bending tube sucks hehe.
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 10-26-2003, 10:36 PM   #4
Bowtiefreak
Bowtiefreak's Avatar
Inline tube or classic tube or many other vendors will have pre-bent lines if you need some.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 10-26-2003, 10:36 PM   #5
orange72350
rubber line. sounds like a good plan. how bout the fittings in steel line? how r they attached?
Old 10-26-2003, 10:37 PM   #6
cableguy0
yes you could run steel braided you just need the correct fitting to plug into the tranny and radiator. rubber is fine too just keep it away from exhaust and other hazards
Old 10-26-2003, 10:56 PM   #7
matt67350
matt67350's Avatar
If you run rubber lines, ground the radiator to the frame.
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 10-27-2003, 12:42 AM   #8
Martin64
Martin64's Avatar
I've ran rubber lines and I've also cut out bad sections of line and made new sections and connceted them using farrell (sp?) connections. Rubber is the easiest. I just added an extra hose clamp to each end.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 10-27-2003, 12:45 AM   #9
orange72350
Y does the rad need to be grounded to the frame? that one has me stumped
dale
Old 10-27-2003, 01:01 AM   #10
Adam12
I hate trannys
Adam12's Avatar
why ground the radiator to the frame? just wondering what that does/prevents?
Old 10-27-2003, 03:55 AM   #11
68LSS1
68LSS1's Avatar
Just need pipe to an adapters for both the tranny and radiator. Shouldn't be hard to find.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 10-27-2003, 09:36 AM   #12
matt67350
matt67350's Avatar
The flow of tranny oil through the radiator make a positive charge
in the radiator. There is a post on this a few weeks back. Just thought I'd pass it on.
Old 10-27-2003, 09:39 AM   #13
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Classic Tube has them already pre-fabbed. Part #CTT1001 for 1970 Pickup/Blazer - 2 Wheel Drive - T-350 $80.00 for Stainless or $45.00 for OE Steel.
And Part #CTT1002 for 1971-75 Pickup/Blazer - 2 Wheel Drive - T-350 and T - 400 $80.00 for Stainless or $45.00 for OE Steel.
Or Part #CTT1003 for 1971-75 Pickup/Blazer- 4 Wheel Drive - T-350 and T-400 $80.00 for Stainless or $45.00 for OE Steel.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-27-2003, 09:40 AM   #14
matt67350
matt67350's Avatar
Oh, the steel lines help make the ground, and if you replace the steel lines with rubber the ground goes away.
Old 10-27-2003, 10:39 AM   #15
Firefighter
Positive Charge? That is strange, I don't guess I've everr heard of that before. What exactly would it do and how would you tell that it is positively charged?? I'm as confused as a baby in a topless bar now!!
Yellville, Ar. USA
Old 10-27-2003, 11:55 AM   #16
/<eystroke
/<eystroke's Avatar
I believe the electricity generated slowly eats the radiator from the inside out. I've never seen on any truck, but that is what I've heard.
'69 C/10 Short Wide
350/400/AC/Tilt/Tach
/<eystroke is offline   Reply With Quote
Old 10-27-2003, 12:22 PM   #17
Firefighter
Actually, since the fluid is conductive, water and antifreeze and transmission fluid, then technically wouldn't it still be grounded through the engine and transmission? Being as the motor is cast iron and the trans is aluminum and there is usually ground straps on the motor connecting to the body and frame.
Yellville, Ar. USA
