08-24-2017, 12:41 PM | #1 |
72 c10 pickup spindle tie rod hole
Hello,
first time posting. i have a 72 C10 pickup and went to change driver side outer tie rod and the spindle hole doesn't have any taper to it. i found it weird b/c when i checked the passenger side it did. must have gotten wollered out. Has anyone used the tapered steering knuckle inserts before? i was trying to keep from buying an all new spindle. From the research i have done it will be 285.00 and up for a pair of spindles and would still need to change my break rotors etc. and it would add up vs a 10 dollar insert. Any help? Thanks |
08-24-2017, 12:47 PM | #2 |
Re: 72 c10 pickup spindle tie rod hole
I would not mess around with that spindle. It's a safety thing.
Find a salvage spindle just like yours but without the damaged part. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-24-2017, 01:03 PM | #3 |
I have called all the salvage and part stores around and no luck. Can you maby sujest a place/phone #
Thanks |
08-24-2017, 01:52 PM | #4 |
You could try craigslist in your area or maybe check the classified portion of this board?
-klb
08-24-2017, 02:57 PM | #5 |
Have you got a photo of your spindle you can post, anybody know if the 73 and up spindles are same, bearing size etc?
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
08-24-2017, 03:57 PM | #6 |
will get a pic tonight.
