Old 08-24-2017, 02:17 PM   #1
krue
Designated A-hole!
krue's Avatar
VATS removal
Where's the best place to have the VATS removed to start an engine on a test stand.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-24-2017, 02:24 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: VATS removal
the guy that setup my ecm removed it...so i would think any ecm programmer guy can do it..but I think they have to buy the license to do it..
Old 08-24-2017, 10:14 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: VATS removal
Find a tuner in your area who you would work with for a full tune (you'd want one for the trans etc anyway) and just ask them if they can do a bench flash. i.e. flash without having the actual car there. The reason is that once you license the credits through HP Tuners, your licensed through the tuners dongle. Doing it through the same tuner, means you won't risk getting doubled on credits, and the tuner is also more likely to give you a break on costs if your return biz is built in. I'm assuming you have something on the test bed that your planning on putting into a vehicle.
Doing a flash for a bench-run only engine is a little different. If you need that, I'll set you up with my tuner.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-24-2017, 10:27 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: VATS removal
In this case I have an 01 4.8l in a truck that the steering column has been cut out of. I want to see if the engine runs so I know what to do with it. I plan on the full tune on the 6.0l going into my truck but for now I just need to see if the 4.8l runs. If it runs I will probably rathole it as a sparefor one of my boys truck since they both have 4.8l.
www.daveramsey.com
Old 08-25-2017, 09:25 AM   #5
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: VATS removal
You have to have a PC with tuning software hooked up to the PCM to remove the vats.
You can send the PCM out to the guy that runs the lt1swap.com web site. He can remove the VATS and other non-essentials for $75 that includes return shipping, takes about a week total from when you ship it out to when you get it back.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-25-2017, 09:50 AM   #6
nsb29
nsb29's Avatar
Re: VATS removal
if your kids have 4.8 just switch ecm's
nsb29 is offline   Reply With Quote
Old 08-25-2017, 04:14 PM   #7
krue
Designated A-hole!
krue's Avatar
Re: VATS removal
Don't see how that will help in a truck with no steering column.
www.daveramsey.com
Old 08-26-2017, 10:14 AM   #8
nsb29
nsb29's Avatar
Re: VATS removal
was not thinking that your kids were still in stock trucks
Old 08-26-2017, 02:26 PM   #9
krue
Designated A-hole!
krue's Avatar
Re: VATS removal
Sorry, yeah one has an 02 the other an 03.
www.daveramsey.com
Old 09-17-2017, 01:44 AM   #10
weim55
Re: VATS removal
You can remove the VATS on the ECM yourself. Take your ECM and plug it into a running truck that takes the same unit. With the engine running in the truck with your ECM disconnect all the plugs in the body control module under the steering column and take the truck for a quick few minute drive. Stop the engine, remove your ECM and your good to go, no vats. I did this on my 5.3 ECM, worked perfectly.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
