![]() Join Date: Jun 2016
Need To Find A 3rd Row Seatbelt Bolt Like These
I have 3, but need a 4th...
Like these: |
Re: Need To Find A 3rd Row Seatbelt Bolt Like These
Those look to be this style. I'm not sure on the exact size of the bolt in your pic but you should be able to match it up and order it from this site. I've done business with them in the past and they have a great selection and are easy to work with.
https://www.boltdepot.com/Hex_bolts_...teel_18-8.aspx |
Thanks nasty...
I've bumped around their site before. But all I could find were the regular hex head bolts. I am hoping to find one like the 3 in the above picture. They are a total of 2" long. The "neck" is 1 1/4" from bottom of head to thread. The head is 15/16" across from point to point... If that helps. Thanks again! |
You might check for a squarebody shoulder harness bolt - not sure of the size but they look like that.
You might also be able to use a regular bolt and make a sleeve/spacer out of black pipe to simulate the shoulder portion. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
