![]() Join Date: Aug 2007
Do I need a 4' lift?
I really don't want to go with a 4" lift and rather a 2 1/2. this is how its is now with
stock springs and 2" blocks on all. Tires are 35s but measure 33. I would like your opinions. Thanks 7D2N
Just for the fun of it |
Re: Do I need a 4' lift?
I would not run blocks in the front not safe. You really need to get the correct lift springs for the front.
![]() Join Date: Mar 2009
I have 2 1/2 lift springs all around with my 33's and they measure 33 inches.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
If you aren't doing anything but poking around the mall and maybe cruising the beach, 2 1/2" will work with 35's and an 8" rim. But if you expect to use it anywhere you might twist it up, you need 4" for 35's. And really a 10" rim to maximize clearance to the springs and the tub.
But those front blocks need to go as the others mentioned. We are getting ready to start a Jimmy for my teenager, and I was able to get 4" springs all around with free shipping so we are building around those and will most likely run 35's to fill the wheel well. It was going to cost almost twice as much to go with 2 1/2" springs, so 4" it is.
I completely redid the 4" lift on my blazer recently. When I bought it it had 4" lift springs up front and blocks in the rear. The rear axle was also swapped for a 14 bolt so my experience may be a little different but here's some of my learning experiences.
1. What I assume was the stock rear driveshaft was too short after the lift as there was evidence that the yoke slipped off the splines and beat up the bottom of the floor. 2. The rear tire appeared to be too close to the front of the wheel opening. Obviously made the driveshaft issue worse when moved back to center it in the wheel well. 3. Not sure who the manufacturer was that made the front leafs that were on it but they were obsurdly stiff. I could jump up and down on the front of the rig and they would not compress whatsoever. I ended up swapping all the springs out for skyjacker soft ride springs. They definitely aren't the cheapest nor are they the best but I think they are a good compromise. Way better than what was on it. I've got 37" military tires and HMMWV wheels on it right now with some bolt on wheel spacers. Everything clears so far for in town driving but would likely rub if twisted up on a trail. |
Thanks guys, I'm finding that the 2 1/2" kits cost more than the 4" doesn't make sense to me but more cost effective. I'm ready to purchase a lift but want it to look right. Anyone running a 4" lift with 35s that you could show me?
Thanks again 7D2N
What prices are the leaf springs going for? My Blazer is lifted quite a bit, (probably 4 inch) and I would really like to go back to stock ride height. Of course, I will need to go to smaller wheels as well.
What are the prices and companies for leaf springs? ![]() Last edited by LuckyScott; 09-06-2017 at 11:18 PM. |
![]() Join Date: Jun 2015
I just put a 4" soft ride in mine. It has 33's on it. I did springs on all 4 corned. At 1st I thought it was 2 high but after driving it I am glad I did 4"
How does it ride now?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
![]() Join Date: Mar 2004
I am running a 2.5 with basically a 33x12.50. (325/60/18).
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
GMC, Craneboy the lifts on your trucks look great. GMC where did you get your 2 1/2 kit?
Thanks 7D2N
Mine is a SKYJACKER. Bought the full kit with new springs front and rear w/ shocks and grabbed a pitman arm from them also.
https://skyjacker.com/shop/suspensio...#configuration
#13 |
![]() Join Date: Jun 2014
You could always post a wanted ad for a factory suspension someone took off their truck if you are looking to save some cash. I sold mine for 100$ on CL after i bought my 4" U-bolts and all. Fit 33x12.50s on an 8" wheel without rubbing issues
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
#14 |
Looking at lift after lift again and again, I plan going with a 2 1/2" lift. I'm going to buy springs first and then misc parts when I can. It seems hard to find a affordable 2 1/2" kit.
7D2N
#15 |
![]() Join Date: Apr 2016
4 inches and 35x12.50/16.5 BFGs on 10 inch rims with axles from 3/4 ton truck (wider track, I think), "minor" fender and quarter panel trimming
Rob "1967 Wanna Be" 1972 K5 Blazer |
#16 |
Personally I like the shackle flip in the rear it allows you to keep falter springs/nicer ride. and it gives you 4 inch of lift.
#17 |
4" 3/4 ton Skyjacker springs all around, no blocks. 33's on 15x8's. Never rubbed anything. Would trade the front springs for 3/4 ton 2" ones if anybody is interested.
'72 K5, known as 'the Fox.' |
#18 |
Well this is going to be harder than I thought. I want the tire to fit in wheel well like it sits now. I have measured the tires with the weight of the truck and and side to side and still 33'' tire size 35X12.50R 15. Stracting my head.
Thanks 7D2N
#19 |
Thanks guys. I struggled with this lift thing and for me cost was is factor. I wanted to keep the tire size so I went with a 4" lift and it will work perfect.
Thanks again 7D2N
