rust fix - floor corners
I stripped my cab floor today and found a fair amount of rust on the passenger side. Does anyone have tips on how to fix it.
I looked up replacement components from auto metal direct and auto body specialties and I'm planning on cutting out the rot and welding in new panels. I wanted to get opinions on whether there was a better way and I want to make sure I'm getting all the right panels. I ordered a kick panel, floor pan and outer rocker, is there anything else I should order? Thanks in advance
Robert 1975 C10 - Huckleberry 2007 Jeep JK - John Wayne Jeep Smittybilt front/rear bumper, 10K winch Pacific Grove, CA |
Re: rust fix - floor corners
You may want to order a cab mount (cab mount brace? or whatever it's called) as well.
Inner rocker, and as mentioned check the floor brace.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
I would love to see a write-up on the project as you do it.
I'll take pictures as I go and post updates. It'll be slow going, but I hope to have it done within the next 2 months. I'll be installing new carpet as well.
I'm doing this currently on a K5. I got my panels from tabco. Made in the usa. You will need an inner rocker also.
I took a lot of measurements before I started cutting. |
