08-27-2017, 11:46 AM | #1 |
72 1/2 ton 4x4 ?
I pulled a trailer yesterday hauling a truck for the first time and it really caused the rear end to squat down badly .I want to add some helper springs ,where do I start ?
08-27-2017, 12:22 PM | #2 |
Post Whore
Re: 72 1/2 ton 4x4 ?
I would add some air bag helpers...I've got them on 3 of my trucks now...they work great...when aired down you never know there on the truck..only drawback is you need a air source but I've got one of those small 12v compressors that also works great.
the first set I had was firestone and they leaked..I've got all airmaxx now and have had no issues... Last edited by mongocanfly; 08-27-2017 at 12:29 PM. |
08-27-2017, 12:26 PM | #3 |
Will that work on a leaf spring truck ?
08-27-2017, 12:30 PM | #4 |
Post Whore
like this.. unless you find one specific to your truck...http://www.ebay.com/itm/Rear-Air-Bag...-/121612192398
08-27-2017, 12:33 PM | #5 |
Post Whore
on my 99 and my 13 1/2ton trucks they are the bolt on kit...on my 81 1ton I used the weld on kit
08-27-2017, 12:33 PM | #6 |
That seems to be an option or add a leaf .
08-27-2017, 12:34 PM | #7 |
Got any pics of the bolt on versions installed ?
08-27-2017, 12:39 PM | #8 |
Post Whore
this is under my 13 z71...
08-27-2017, 12:42 PM | #9 |
Very helpful ,Thankyou .
08-27-2017, 01:11 PM | #10 |
20' Daredevil (Ret)
Another option - I have LP-35 overloads on my K20. http://www.hellwigproducts.com/produ...ad-pro-series/
08-27-2017, 02:39 PM | #11 | |
Airbags are great as they allow adjustable control over the load and empty ride is unaffected but they are the priciest option. Underspring overload springs are the cheapest option but offer the worst empty ride as they always have the rear springs stiff.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
08-27-2017, 07:46 PM | #12 | |
20' Daredevil (Ret)
08-27-2017, 07:52 PM | #13 |
Any idea of cost for the LP-25 overloads as I saw no pricing ?
08-27-2017, 08:59 PM | #14 |
Post Whore
found these flashed..https://www.summitracing.com/search/...MobileSwitchNo
08-27-2017, 09:15 PM | #15 |
Thanks guys .
08-28-2017, 07:59 AM | #16 |
I've used the Air Lift auxiliary springs (air bags) in a few applications. That add up to 1500# extra of true capacity when aired up and it's like they aren't there when aired down. I have used them on a 1t '92 rather than re-arch the tired leafs. I leveled the truck back up, w/o making ride harsh, and had better than new towing abilityby adding air.
I never used an onboard compressor. I'd air up at home before the haul or stop at a service station when out. Add-A-Leafs I feel do very little toward adding capacity. At least that's my experience. I've never used the helper springs, but adding capacity is their purpose and Hellwig makes stuff that works. Add-A-Leafs are about the lift
08-28-2017, 05:13 PM | #17 |
Post Whore
and another plus to the bags is I can comtrol the height of my truck depending on the load....4 wheeler in bed doesn't need as much air as my 20ft trailer with a load on it...whatever the load I just air up til truck sits level..
and if I'm not at home I just use my cigarette lighter air pump... |
08-29-2017, 11:42 AM | #18 |
I pull 10,000 lbs regularly with my pickup. I have 2" Tuff Country EZ rides with the LP 25 OL's in the pic. I have rolled across the scales at 19,890 with a fifth wheel. The truck weighs 6,200lbs. I hit the bolts with a ratchet when i want more preload and back them off when i dont. The only thing i recommend is keeping a bit of preload on those springs even when not loaded because if not they will bounce off the spring pack. This happened to me on back road/off road and over wash board. Other than that they have worked very well for the price.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's Last edited by snj8198; 08-29-2017 at 12:11 PM. |
08-31-2017, 06:03 PM | #19 | |
try to buy a set of airbags from a company that warranties them for life, mine started cracking after like 4-5 years, i had the original box just not the receipt and they replaced them free of charge |
09-01-2017, 04:13 PM | #20 |
I have bags on my Duramax. I paid a little extra & got a set w/ jouncers inside so they can be run 0 psi if need be & won't hurt the bags. I forget if Air Lift or Firestone...
09-01-2017, 05:12 PM | #21 |
I didn't know that was offered. What's the minimum pressure, 80psi? I don't remember it being enough to affect the ride. Still a nice feature.
09-01-2017, 06:26 PM | #22 |
Post Whore
80psi? nonono..them things would be aired all the way up..aired down pressure for the firestones is 5psi recommended. .
09-01-2017, 06:31 PM | #23 |
Post Whore
this is from their site.
When not needed the minimum air pressure you need to keep in Ride Rite air bags is*5 psi*to prevent them from damaging themselves. When you are towing you basically want to inflate the bags till the suspension on your vehicle sits level again. Whatever psi accomplishes that would be the correct amount. |
09-02-2017, 08:18 AM | #24 | |
the directions really dont give you a setting you just kinda try different pressures and see what works, i usually have them at 10 when im empty |
09-02-2017, 12:15 PM | #25 |
It's been a while since I've used them. I just remembered the 80psi number. Makes sense that would be pretty dang inflated. I've used them inside coils as well as the auxiliary ones with leafs. want to get some for my '72 once I deal with the rear suspension. I lifted by using add-a-leafs and 2" blocks due to low budget. I didn't like the fit of the u-bolts with blocks so I went with Ruff Stuff top plates and u-bolts. Real HD stuff, but now the plates bottom out with a modest load. I also was concerned that EZ-rides may not handle as much weight, yet didn't want a harsh ride. I'll go with the 4" EZ-rides and air bags at some point. Them there are the tight riding front springs I bought. Don't want hard front/soft rear, so need front EZ-rides. In the end, it is costing more to be cheap.
