Old 08-27-2017, 06:01 PM   #1
MiraclePieCo
MiraclePieCo's Avatar
How do I remove the wood from a panel truck floor?
49 panel truck. I want to remove the wood floor without damaging it. What's the procedure? Looks like even if I remove the innumerable bolts it's still trapped front and rear by metal runners.
MiraclePieCo is offline   Reply With Quote
Old 08-27-2017, 09:35 PM   #2
67GMCkid
67GMCkid's Avatar
Re: How do I remove the wood from a panel truck floor?
50 and later had a plywood floor with 5 metal strips and the bad news is, I believe the body was assembled on top of the flooring.. I could be wrong, I haven't spent much time under that end,,, yet..
67GMCkid is offline   Reply With Quote
Old 08-27-2017, 10:03 PM   #3
Mac the Yankee
Worse comes to worse, you can always cut/remove the lip of metal holding the floor in, take the wood out, then weld the lip back in. I have a '56 panel with a great floor- may consider doing the same thing
Mac the Yankee is offline   Reply With Quote
Old 08-28-2017, 06:14 AM   #4
MiraclePieCo
That's what I'm thinking, except not bother welding the lip back in. It would then be removable from the top, similar to pickup bed wood.
The way the wood is trapped in on both ends, it does indeed appear that the truck was built around the wood. Nice photo, btw.
Old 08-28-2017, 08:57 AM   #5
67GMCkid
67GMCkid's Avatar
The plywood floors are one solid sheet of 5 ply and are routed for the metal bands to sit into so getting the front and rear ends free is only half the battle, the sides of the body will still bolted/sitting on the outer edges..
If you are trying to save the plywood you only have two options, reverse assemble it or do a lot of bracing and lift the body..
Old 08-28-2017, 10:35 AM   #6
Mac the Yankee
I'll check, but I'm pretty sure that both of my 1/2 ton panels ('56 and '59) have separate wood planks.
Old 08-28-2017, 11:35 AM   #7
_Ogre
_Ogre's Avatar
all tf panels had plywood floors
hard to replace unless you have access to 52'' wide marine plywood
shop air compressor timer
Old 08-28-2017, 01:22 PM   #8
MARTINSR
MARTINSR's Avatar
Couldn't one of the metal strips be removed in the center, a cut made in the wood to be hidden by that center strip, then you have two pieces that can be removed pulling them out from under the body?
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 08-28-2017, 01:58 PM   #9
MiraclePieCo
Brian
That's sorta what this guy did:
https://www.stovebolt.com/techtips/f...urb/index.html
