Old 08-27-2017, 10:09 PM   #1
TheRedBarron
Ignition problems?
Having an issue with my 62 C20 not turning off the ignition when I turn the key to off. All the electrics stay on even with the key in the off in the off position. It happened to me twice before, but when I drove the truck and parked it again it worked fine.... Just now it hasn't been turning off for the past four days. How would I check for a short? Should I suspect the ignition switch and relay?
TheRedBarron is offline   Reply With Quote
Old 08-27-2017, 11:05 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Ignition problems?
Lots of info to look through here:
https://www.google.com/search?domain...D%3A1%3B&hl=en
Old 08-28-2017, 12:44 PM   #3
TheRedBarron
Originally Posted by The Rocknrod View Post
Thanks for the extra links, there was a few that I didn't see. I think I can eliminate the alternator as I kill the truck in third gear to stop it, but the electrics stay on, which doesn't seem to be a topic that was on that list. I'm thinking it's either a short or the switch.... So I bought one from Napa. Let's pray to the classic car gods that it's just the switch and I won't have to go chasing wires.
Old 08-28-2017, 12:58 PM   #4
The Rocknrod
Moderator
Do you have a voltage regulator or an internal voltage regulator in the alternator?
Old 08-28-2017, 02:04 PM   #5
TheRedBarron
I'm assuming internal, because I don't see a regulator.
Old 08-28-2017, 02:46 PM   #6
The Rocknrod
Moderator
Did you read the threads about the diode?
