08-28-2017, 11:58 AM | #1 |
How maney cores
I am trying to figure out how many corers the original radiator for my 62 has. It is around 2-3 inches thick. The finned part of the radiator is the same thickness as the top part that the upper hose connects to.
08-28-2017, 12:02 PM | #2 |
Re: How maney cores
Here are two photos. I don't have a side photo.
08-28-2017, 03:38 PM | #3 |
Re: How maney cores
If original v8 should be 3 or 4. I was told my 62 core was a V flow, not cross flow. Cools better. So if a good core do not replace! I Run a 406 small block in Vegas heat with my stock radiator.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-28-2017, 03:44 PM | #4 |
Re: How maney cores
Heres my Flex-a-Lite Black Magic 3300cfm fan
08-28-2017, 03:49 PM | #5 |
But Found Her 25yrs Later!
Re: How maney cores
My 65 is on a 62 Gmc Frame. It had a 351 V6 in it. When I went to a V8, I used the GMC V6 Radiator. It's still in there to this day:
[/QUOTE]
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-28-2017, 04:01 PM | #6 |
Re: How maney cores
Is that factory Shroud? I did not have one but used the 6 tabs to mount this fan
08-28-2017, 05:19 PM | #7 | |
Re: How maney cores
take off the rad cap and you can see or feel the number of rows. I've been researching replacement radiators , it seems the size of the core is important, ie a 4 core with smaller diameter cores may not cool as well as a 3 core with larger cores.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
08-28-2017, 06:15 PM | #8 |
Re: How maney cores
The Shroud in my pic above is the original 62 Shroud.
