Old 08-28-2017, 09:54 PM   #1
hdixon
Brakes
Can anyone help me out I have a motor with a really big cam and it is causing very little vacuum for my power brakes what would be the best way to goon my c10 step side 12v electric vacuum pump brakes? are Hydroboost brakes?
hdixon is offline   Reply With Quote
Old 08-28-2017, 10:34 PM   #2
hdixon
Re: Brakes
Originally Posted by hdixon View Post
Can anyone help me out I have a motor with a really big cam and it is causing my engine to have very little vacuum for my power brakes. what would be the best option to go with 12v electric vacuum pump for brakes? are Hydroboost for brakes?
any help would be great
Old 08-28-2017, 10:59 PM   #3
cdub2010
Re: Brakes
I have a few supercharged vehicles with hydroboost brakes. I would use a hydratech kit or something similar. Im running manual brakes on my c10 and will install a hydroboost once my truck is faster than I can stop.
cdub2010 is offline   Reply With Quote
Old 08-28-2017, 11:29 PM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Brakes
Depends on your budget. You may be able to pick up a hydraboost system cheap at a wrecking yard, but most of them use a later model master cylinder. You could switch to a manual brake master cylinder, which is even available for disc brakes, and just ignore the low vacuum signal altogether. The pedal effort is about like manual drum brakes. Even my wife can stop our van with hydraboost, if the engine quits.
~Steven
Simi Valley, CA
Old 08-29-2017, 10:14 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Brakes
You can try a vacuum canister. It goes in line between the vacuum source (engine) and the power brake booster. It stores vacuum until you push the pedal down. It's usually only good for one, maybe 2 pushes of the pedal until it builds up more vacuum. But that happens fairly quick.
What does "goon" mean? Or maybe a spelling thing...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-29-2017, 11:54 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Brakes
I'm guessing "go on".
Didn't some diesel pickups -- Fords, maybe -- use small belt-driven vacuum pumps? Combined with a canister, something like that might do the trick.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-29-2017, 01:33 PM   #7
bs46488
Re: Brakes
My neighbor did the vacuum canister and always complained about it.
I went with a hydroboost setup that I build from factory OEM parts. The Hydratech kits are setup nice, but a little pricey. With a little research you can use the OEM parts and save some $$$
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 08-29-2017, 03:15 PM   #8
67 chevelle
67 chevelle's Avatar
Re: Brakes
The vacuum canisters are basically useless , hydroboost works great on big cam low vacuum engines
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-29-2017, 04:54 PM   #9
ThePunisher67
Re: Brakes
HydroBoost is so over rated and over priced it is not funny He would be better off buying a 12 volt vacuum booster. These trucks have many Areas to hide 1. Unless you fined a used 1 that works for a decent price I have not found a decent 1 for a while. Let me know if you find 1 for a decent price. The Cheapest I have found is 500+. I found a 12 volt vacuum pump for 125. I just cant make up my mind.
ThePunisher67 is offline   Reply With Quote
Old 08-29-2017, 06:29 PM   #10
edhtrd71
Re: Brakes
When I worked at the Cadillac dealership we had a bulletin with the CTS. We would install a 12V vacuum pump, plumbed to the booster to assist the brakes. It was mostly for cold start periods where the engine was not making much vacuum while caused by aggressive cam timing. I don't remember the years affected. On the other hand I recommend manual brakes. I had power brakes but switched over to manual brakes with a wilwood master and adjustable prop valve. I have no complaints and no plans to switch back. I looks way cleaner under the hood also. Hydraboost is just a power steering leak waiting to happen.
edhtrd71 is offline   Reply With Quote
Old 08-29-2017, 07:25 PM   #11
Bigdav160
Bigdav160's Avatar
Re: Brakes
I was going to suggest looking for a powermaster brake setup off a mid 80's GM station wagon (same unit on Grand Nationals) but dang those things are bringing good money on eBay.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
