08-28-2017, 10:52 PM | #1 |
1974 C10, No Power With Key In Accessory Position?
Hello everyone.
When I turn the key backwards to the accessory position on my truck, should I get power at the fuse box? (besides the fuses that are always hot.) I can hear the rod moving in the collum when I turn the key back, and can hear the switch click. We should I be seeing power at the fuse box in the ACC. position? I'm going to be adding some 12 volt accessories soon, and need to tap in for power and I'd like it to be on the accessory circuit. Like I have set up all my cars in the past. Is this an ignition switch issue? Thanks -Gavin
Keep on truckin' |
09-03-2017, 01:02 PM | #2 |
Re: 1974 C10, No Power With Key In Accessory Position?
It should does it have main lead to part of the fuse box.
Does your truck have the radio delete option from factory, might not have + lead accessory. Or the fuse is blown, wire cut. Could be the ignition switch (On lower part of the column burned on the ACC lead part or dirty.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 09-03-2017 at 01:11 PM. |
