Old 08-29-2017, 09:56 AM   #1
72peace
72peace's Avatar
Doooeeesn't quite look right
So i'm doing a frame off and was looking at the front end, and something looks a little off, but i'm not sure what to replace. Help me out here guys.
72peace is offline   Reply With Quote
Old 08-29-2017, 10:03 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Doooeeesn't quite look right
Are you concerned with the control arm sitting on the spring "cup"? With it suspended off the ground the it will look wonky. Set it on the ground and it will move up off of the cup. If those are lowering springs they will change the caster and/or camber.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-29-2017, 10:08 AM   #3
72peace
72peace's Avatar
no drop springs, looking forward it just looks like the drivers side is turned in way more than the other. Almost like somethings bent.
Old 08-29-2017, 10:16 AM   #4
raggedjim
raggedjim's Avatar
As you put weight on the frame the tires won't be splayed out as much. Do you have the upper a-arm shims installed? It looks fine to me...
Personally, I'd get it good enough to drive then take it to an alignment shop.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 08-29-2017, 10:21 AM   #5
72peace
72peace's Avatar
So once I get the cab and engine back on it should straighten up?
Old 08-29-2017, 10:33 AM   #6
GASoline71
GASoline71's Avatar
It will get closer to looking right as weight is added back to the frame (engine, transmission, cab and body).
Gary
Old 08-29-2017, 01:27 PM   #7
demian5
demian5's Avatar
Maybe you are missing a bump stop.
Mine looks the same when jacked up.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-29-2017, 01:33 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Yeah, it looks like the bump stomps might be missing, and about 3,500 lbs of truck...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
