Old 08-29-2017, 03:24 PM   #1
Swedchevy67
Front Sway bar
Need help to get right front sway bar for my 67 Chevy truck longbed.
When you I bought it there where no sway bar on it.
On my lower control arms there are 2 drilled holes, which I believe is the mounting holes for the hardware and fastening.
Anyone recently bought one, please give me the product name.
Stefan
Swedchevy67 is offline   Reply With Quote
Old 08-29-2017, 03:52 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Front Sway bar
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=66
$ 180 for the bar and all mounting components....
AussieinNC is offline   Reply With Quote
Old 08-29-2017, 04:59 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Front Sway bar
Hi and welcome from Western Canada. Attached is pretty much all the info yiou need to install a front sway bar on your truck.. If you could find a a 1973-1987 Chevy C30 or GMC 3500 1 ton truck in a wrecking yard it would have the desireable 1 1/4 inch front sway bar, but maybe thats a tall order in Sweden.
http://67-72chevytrucks.com/vboard/s...d.php?t=72338r truck.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 09-02-2017, 07:54 AM   #4
Swedchevy67
Re: Front Sway bar
Stefan
Here some pictures
Old 09-02-2017, 07:56 AM   #5
Swedchevy67
Re: Front Sway bar
The first pic shows the distance between the mounting. 60 cm (23,6 inches)
Old 09-02-2017, 08:06 AM   #6
Swedchevy67
Re: Front Sway bar
The second show the distance between the two holes on the lower bearing
and the distance are measured as the other pictures shown (where I laid my pencil) That distance are 94cm (37 inches)
Old 09-02-2017, 12:50 PM   #7
Already Gone
Re: Front Sway bar
If you read that link I put in my first post it explains everything.
Old 09-02-2017, 07:59 PM   #8
mikecaddy500
mikecaddy500's Avatar
Smile Re: Front Sway bar
CPP has a 1 1/4" that is good quality. I am currently installing one on my 72 c20. The stock one is 1". I will take some pics later. If you want a stock one, I can clean up my old one and send it.
mikecaddy500 is offline   Reply With Quote
