08-29-2017, 07:23 PM | #1 |
Where to buy anodizing remover?
Any brands of anodizing remover you recommend? I plan on building a tray to put my trim and grill in.
Posted via Mobile Device |
08-29-2017, 07:46 PM | #2 |
Re: Where to buy anodizing remover?
I've used Easy-Off oven cleaner to remove clear anodizing from trim pieces.
08-29-2017, 08:07 PM | #3 |
I took my 1972 outer grill to a media blaster in Maryland. He used crushed glass I believe and my grill came back GORGEOUS. I'll have to polish it from time to time but I have had in it my living room for nearly two years and it still looks great.
08-29-2017, 09:42 PM | #4 |
Most any oven cleaner or drain cleaner should work as long as it is sodium hydroxide. I used the product pictured below on a spare grille. I brushed it on the grille. Then, after a few minutes, I used fine steel wool and rinsed the grill with water. I got the drain cleaner at Home Depot if I recall correctly. I don't think you will need any sort of tray.
08-29-2017, 10:24 PM | #5 |
I found one that you mix with water is why I talked about building a tray. I tried oven cleaner but am worried about ruining all of my aluminum parts.
08-30-2017, 09:08 AM | #6 |
