![]() Join Date: Oct 2016
Seeking source for front stub axle slingers and innershaft axle tube debris deflector
hi, i have a 71 k5 4wd and am rebuilding/restoring the dana 44. im in need of the 2 parts mentioned in the title. they are simple metal discs w/flanges that press on the axle shafts. does anyone have any parts #s or know if a plastic 2 piece (omix-ada) will work for the inner axle position, thanks, chris.
Re: Seeking source for front stub axle slingers and innershaft axle tube debris defle
Spicer p/n 36364, purchased from Denny's Driveshaft, $2.95 each. These fit the larger 5-760 u-joints, I don't thing they fit the smaller u-joint axle shafts & I don't think the smaller slingers are available (could be wrong on this).
One of the First
![]() Join Date: Jan 2000
I have a complete rebuilt set of axle shafts and spindles (CHEV 1972/ 1/2 ton / D44/ small crosses)) with all working/nice components that I would part with. It took alot of man hours to find all the parts to rebuild these guys, the small inside slingers are not reproduced / the small brass washer are almost impossible to locate a set these days.
After a few years, I swapped out for larger axles, joints and spindles, which is rather expensive. I 4-wheel alot. Shoot me a PM if intrested.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Post Whore
![]() Join Date: Feb 2016
Try calling Woody's 4x4 in Vancouver WA. They have helped me out with parts in the past.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
