08-29-2017, 10:35 PM | #1 |
wiring from A pillar to door "boots" ?
What "boot or wiring protector would you recommend or what are you using to pass wiring from A pillar to door name, company, part number ?? Pics would be awsum ! 'Preciate ur input Thanks !
08-31-2017, 10:32 AM | #2 |
Re: wiring from A pillar to door "boots" ?
Anyone ????
08-31-2017, 10:41 AM | #3 |
If you search for "Door" and "Loom", you'll find a bunch of threads where folks have discussed wiring the door jambs.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
08-31-2017, 10:42 AM | #4 |
You can find what you are looking for at McMaster-Carr Industrial supply....google this.
Then search under 'push-in grommets'. After that, you need only pick the inner size/diamter you want or need and the thickness of the sheet metal...noting that the rubber grommets are pretty flexibile and will fit a lot more holes and thicknesses than just what is listed. ...all of this is assuming that the grommet is what you are after. If you are looking for a 'sleeve' or something like that....try searching for that on McMaster Carr because they probably have it. Regardless...try McMaster Carr....they are a great professional/industrial company and ship very fast, I use them all the time. (Also note that a lot of local 'NAPA' style auto parts stores have trays and drawers of this stuff available....they are worth checking out as well) All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
08-31-2017, 11:08 AM | #5 |
Here is what I used.
Keep It Clean 10620 Door Loom Rubber Door Loom Picture attached installed |
08-31-2017, 10:14 PM | #6 |
I didn't use anything. I hid my wiring on the outside of the upper hinge, and you can't see a thing with the door open. I forget it is even there. I think i have 4 or 6 wires going to my door locks. Been in there 10 years without a hickup. Nothing wrong with the loom, etc, but i like to hide as much of my mods as possible.
09-08-2017, 08:39 AM | #7 |
I used grommets and just offset the holes about 3" between the pillar and door. Wire folds that way and stays clear of door.
But a neat solution using factory stuff would be 67-69 Camaro power window wiring boots.
01-31-2018, 12:00 PM | #8 | |
01-31-2018, 10:06 PM | #9 |
pm me your phone number and i will text you an image. Then i will try to get it off my phone to this thread. Real busy with the house from hell projects right now. Thanks for the interest. Good luck!!
01-31-2018, 10:25 PM | #10 | |
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-31-2018, 11:19 PM | #11 |
On my 70 GMC I used a product from Specially Power Windows called Flexible Stainless Steel Wire Conduits (FWC). I also have a set on my 1967 Cutlass since 2011 without issues. These are in available in 1/2 inch or 5/8 inch diameter. These can give you a very clean installation. They are also available with Aluminum Bushings (FWC-BA). These are not listed in their product line. You will find them under 'Support' on their website. If I remember correctly cost is around $50.
Specialty Power Windows is located in Forsyth, GA. They've been around for years.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
02-01-2018, 01:47 AM | #12 | |
