Old 08-30-2017, 12:02 PM   #1
mteribery
Steering Column Firewall Plate?
I recently bought a '63 C10 that has an aftermarket tilt steering wheel. The problem is its missing the plate that attaches to the firewall. Any suggestions where to find one? I've been looking everywhere.
(I also know I have to relocate the emergency brake cable, I just haven't yet.)
Thanks!
mteribery is offline   Reply With Quote
Old 08-30-2017, 12:29 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Steering Column Firewall Plate?
I thought that was a rubber gasket that fit there, no plate.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-30-2017, 12:30 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I found a decent one several years back when a friend bought a cab for the dash. It wouldn't be too difficult to fabricate one. Here is mine for reference purposes.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-30-2017, 02:38 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Or you could call and ask any of these guys:
http://www.aspenautoaz.com/60-66-chevy-truck-parts.html
http://www.4-5-6chevytrucks.com/used-parts.html
http://ctcautoranch.com/index.html
Or you could ask a member here named - vetnat
Old 08-30-2017, 04:31 PM   #5
forestb
forestb's Avatar
Is the plate that vin63 posted the right plate for that style hole?
forestb is offline   Reply With Quote
Old 08-30-2017, 04:56 PM   #6
vin63
vin63's Avatar
I'm not aware of another style plate for the 63-66. I believe the 60-62 were curved and oblong in shape.
Old 08-30-2017, 06:13 PM   #7
chevy_mike
chevy_mike's Avatar
Ah, that pic makes more sense. Yep, should be fairly easy to fab.
Old 08-31-2017, 08:21 AM   #8
mteribery
Thank you! Just ordered one from Aspen Auto!
Old 08-31-2017, 08:22 AM   #9
mteribery
That helps a ton! Looks like I need to purchase the seal as well, I just ordered the plate from Aspen Auto. Thanks!
Also, where did you find the catalogue at? I'd love to order one!
Old 09-01-2017, 11:20 AM   #10
YOLO
Custom Truck Lover!
YOLO's Avatar
[QUOTE=mteribery;8028913]That helps a ton! Looks like I need to purchase the seal as well, I just ordered the plate from Aspen Auto. Thanks!
Also, where did you find the catalogue at? I'd love to order one![/QUOTE
Nick at Aspen is the man. The other part is a rubber seal.
Squarebody guy
YOLO is offline   Reply With Quote
Old 09-06-2017, 08:50 AM   #11
mteribery
[quote=YOLO;8029754]
How long does it take for them to ship items? Just curious, I ordered a part a week ago but haven't heard anything.
Thanks!
1963 Lifted C10 4x4 Long Bed Fleetside http://67-72chevytrucks.com/vboard/s...37#post8028937
Old 09-06-2017, 10:41 AM   #12
mteribery
Which catalogue is this and where could I find one? Thanks!
Old 09-06-2017, 11:35 AM   #13
vin63
vin63's Avatar
There is a similar diagram in my 1963 Chevy truck shop manual.
Old 07-15-2020, 09:03 PM   #14
DonLeverton
There are 2 different parts if you look closely. One is the tin plate that bolts down with 4 screws. The other part is dense foam rubber that seals the column to the firewall.
DonLeverton is offline   Reply With Quote
