Built a bed lifter
I will be putting the bed on and off the truck countless times over the next year or so as I begin building 2 1965 GMC trucks side by side.
The bed is not that heavy but it is awkward and I want to be able to do this with out any help if I am alone as I work late at night after I close the shop so having a bed lifter is a necessary tool. So I converted my cherry picker into a long reach crane by building a new boom extension and extending the forward wheels and arms to make it stable. I built the lift frame out of 1" square mild steel I also incorporated my engine "tilter" and that makes getting the bed at exactly the right angle a piece of cake. A ratchet tie down to control the side tilt took care of that wobble as well. So here are the pictures of it in the bed for the first time. Last edited by Robert Haas; 08-31-2017 at 08:27 PM. |
Re: Built a bed lifter
Thanks for the Idea, By The Way NICE SHOP!
![]() Join Date: Dec 2009
Great Idea.
Very Nice
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Nice!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Used the same concept, albeit in wood, when installing the bed on our '65. It worked perfectly. The photo is from a installation timelapse, which I'd post if Photobucket wasn't holding everything hostage. Unfortunately I do not have a better photo.
Moderator
![]() ![]() Join Date: Aug 2011
I used straps and an engine hoist on my stepside.
Never said this was the only way to do this. This is just how I decided to go about it. We all have our own processes and no one way is best. I will be setting the bed on and off the frame once I have the frame up on the frame rack so I went this route. |
#10 | |
Moderator
![]() I think what and how you did it was the best I have ever seen. ![]()
It's Better With Nitro
Here is mine - adjustable H configuration. One of the best tools I have especially when I'm by myself and need to lift and reposition beds and one piece front ends.
