Old 08-31-2017, 11:04 PM   #1
ShortCST
ShortCST's Avatar
Sorry, Stupid Question: Best Lubricant For Hood Hinges? How About For Door Locks?
I figured you guys would know better than the guys at the parts counters.
ShortCST is offline   Reply With Quote
Old 08-31-2017, 11:11 PM   #2
Bigdogg
Re: Sorry, Stupid Question: Best Lubricant For Hood Hinges? How About For Door Locks?
I like white lithium grease myself or silicone lubricant.
Bigdogg is offline   Reply With Quote
Old 08-31-2017, 11:17 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Graphite powder for door locks, [also house locks]. Does not attract dirt/sand which could jam the works. Aerosol white lithium is OK for hood hinges, except it's white and the hinges are black. I've also used regular ol' WD40 on the hinges without ill effects.
And the only stupid question is the one you're afraid to ask.
'68OrangeSunshine is online now   Reply With Quote
Old 08-31-2017, 11:23 PM   #4
Bigdogg
yea when I spray the white lithium I use the straw to get into the places I want and wipe off any excess. but WD40 is good also
Old 08-31-2017, 11:38 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Guys, about graphite in door locks: I have no knowledge or experience but Leon (LockDoc) has plenty of both. Here's his take on it:
Originally Posted by LockDoc View Post
I respectfully disagree about the graphite though. The main problem with graphite is that it attracts moisture, and after a few uses it builds up and becomes a sticky paste. I have disassembled a LOT of door and ignition lock cylinders and the ones that had graphite used in them were in much worse shape than any of them that were lubed with a spray lube. I know part of the problem is that people get really carried away with it though. It's the old adage that if a little is good a lot must be better.... If a spray lube with Teflon is used there is no oil to attract dust and dirt. Any lock will have a buildup of contaminants if they are not flushed once in a while with a good penetrating oil. I never recommend Graphite for any lock cylinder.
LockDoc
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-31-2017, 11:46 PM   #6
ShortCST
ShortCST's Avatar
A bunch of fantastic info, thank you all! I have white lithium grease in a spray can for the hinges, and I have Tri-Flow with Teflon for the door locks! I'll go do it in an hour or so, just in case someone breaks into the conversation in the nick of time with a dire warning about either product.
Old 09-01-2017, 01:49 AM   #7
'68OrangeSunshine
Interesting. This quote is from another thread? [Not sure how to do that trick myself.] LockDoc is a pro, so his opinion has some weight on this subject. I wonder why they sell that graphite powder?
We don't usually have a lot of humidity in Arizona. But I did have some difficulty entering the key into my front door lock during the recent monsoon season... Perhaps a related issue? I wanted to give it another shot of graphite, but couldn't find the tube. Now that the summer rains here are mostly over, the problem went away. I'll have to get some more Break Free.
Old 09-01-2017, 06:42 AM   #8
I like Tri-Flo. White lithium is great on hinges and it lasts because it's a grease. Oils, silicones, etc. require more often application. And cleaning/flushing is important for any product that clings.
Old 09-01-2017, 08:07 AM   #9
Katrina/10
Katrina/10's Avatar
A few drops of motor oil on the hood hinges. I don't like the residue the white spray grease leaves.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-01-2017, 09:18 AM   #10
Warrens69GMC
Warrens69GMC's Avatar
For the hood hinges, i have been using marine grease and PB blaster. Marine grease applied with brush (flux) and PB blaster to get it in the crevasses.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-01-2017, 02:21 PM   #11
In The Ten Ring
Crap! I've been using butter!
Haven't lubed anything yet, hopefully soon. I have lots of lubes as I used to sell for ZEP Inc.
In The Ten Ring is offline   Reply With Quote
Old 09-01-2017, 04:14 PM   #12
RedRider
RedRider's Avatar
X2 for Tri-Flow. Use it on everything from mountain bikes to AR-15's.
RedRider is offline   Reply With Quote
Old 09-01-2017, 09:40 PM   #13
gvw5400
gvw5400's Avatar
Back when my daily driver was a 1980 K20 I used WD-40 monthly to prevent the dreaded
Kinked hood on the square bodies. I got a can of Triflow and decided to give it a try,
It lubed so much better than WD-40 the hood would not stay more than half way open!!!!
No kinked hood, but it was about 1 1/2 years after even cleaning the hinges with brake cleaner before the hood would stay open!!!
All the best, Dirk
gvw5400 is offline   Reply With Quote
Old 09-02-2017, 12:06 AM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep. Post #6 in this thread http://67-72chevytrucks.com/vboard/s...28#post7568928
This is the first time I tried it, and it's easy. Just do what you would to quote the post, then copy that quote and paste it into your new reply.
- Mike -
RIP El Jay
