headers,what type for a 350 in a 68 chev.?
Hey guys, i'm putting a 350 into my 68 and I haven't ever owned one before, so i was wondering what's a good set of headers i can put on it. I was thinking of block huggers, but i was wondering if there is a good brand, possibly a part number or summit number or jegs number, if any of you have a setup that works good maybe even some pics, let me know, thanks alot, nate
Cobalt turned me on to these, Hooker Super Comps, part# HOK-2452-1. They fit awsome!! Almost forgot, I got them from Summit Racing.
Here they are
One more
Watch out for your cornhole !
![]() Join Date: Jun 2003
These are the Summit brand Jet-Hot coated headers. When I unboxed them, they were actually DynoMax brand headers. It was a pleasant suprise. The downside is the collectors hang low underneath the truck. Terrible for one lowered a lot.
That said, I have always run Hooker Comp headers, not the Super Comp ones. Never had a complaint at all and they're lots cheaper than the Super Comp models.
other side
underside
67-72 Addict!
Tx, how old are those?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I need more money....
Before you buy headers, verify what position your 350 is mounted in. If it is in the factory 6 cyl position, I think that some of the headers will not fit properly without modification, because they will run into the firewall, or steering linkage or something like that. If it is in the factory V8 position you should be fine.
Someone correct me if I am talking out of my ass here. :p But this is what I read. Just a heads up.
Jay. ![]() ![]() '68 LWB C10 '74 Duster ("It's not Rusted out, it's been modified for weight reduction") '91 Civic '97 Saturn '88 Celica AWD turbo (R.I.P.) 273 hp Mustang Killer |
hey everyone, thanks for the replies, but i forgot to add that my truck is pretty low here's a pic of it. also how do i tell if it's in the v-8 or v-6 position?
Once again....Sanderson....nothing better! They have block huggers that are perfect for a low rider, and have the best flange in the business.
#13 |
I would decode your VIN and see if the truck was a 6cyl or 8 cyl from the factory. If it was a 6 cyl, and has been converted to an 8, I would assume that it would still be in the 6cyl position. ( I think only a few people would bother changing the mount positions and getting the longer driveshaft etc.) If it is in the 6 cyl position, it will be sitting close to the firewall. Maybe someone else can elaborate on this, or supply a pic, as my 68 still has the original 250 in it right now.
#14 |
hey charlie are you talking about these ones? also i checked the vin number and it came stock with a v-8.
#15 | |
#16 |
hey randy do those hooker super comps hang below the frame, it's hard to tell in the pic because it looks like it's at an upward angle.
#17 |
Formerly yellow72custom
Can't you use 3/4 lenght Chevelle headers on trucks for better ground clearance?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#18 |
i heard something about this before, but i don't know any other info other than that, so if anyone knows more about the chevelle headers, let us know. thanks.
#19 |
Nate003
Those are the ones. They are short, so clearance is not an issue. Their flange design has the best seal in the industry. They cost more, but are worth it. |
#20 |
Thoughs are Sandersons CC3. They can be used in the stock V8 postion. I bought a set for my 69 and fit real well. A bit pricy but you dont have to use gaskets either.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect. |
