09-01-2017, 02:45 PM | #1 |
Screws
Where can I get the screws to secure the cowl hood as a set or what size are they. Thanks in advance
09-01-2017, 03:14 PM | #2 |
20' Daredevil (Ret)
Re: Screws
Are these what you are looking for?
http://www.classicparts.com/1967-72-...info/38%2D173/ http://www.classicparts.com/1967-72-...info/38%2D159/
09-01-2017, 06:47 PM | #3 |
Re: Screws
The size of the tap screws is debatable. Personally I believe they're a large #8 or small #10. I would start with #8, which is what I believe the part houses offer anyway. Keep that in mind as you read the following:
The panel mounts onto the cowl using six phillips tap screws with integrated washers. The screw threads are #10" x 5/8". These screws also hold the cowl seal in place. The panel also mounts to the cowl using four phillips stainless steel tap screws & U-nuts."" The screw threads are #10 x 1/2". The holes for these are nearly parallel of the windshield wiper mounts. The U-nuts are 1/2" x 5/8, and the hole center to edge is 1/2"". The panel also mounts using four 1/2" recessed hex head tapered screws with integrated washers. One fits behind each door, and one on each corner of the cowl. The threads on three of these screws are 5/16-18 x 7/8. The thread on one screw is 5/16-18 x 3/4. The shortest thread was used behind the RH door, which probably means nothing. 3/4" or 7/8" should work. Also, they don't have to be tapered. They just happened to be on the truck I'm rebuilding.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-02-2017 at 01:42 AM. |
09-01-2017, 07:24 PM | #4 |
Re: Screws
Thanks for the info. Best site for our c10s.
09-01-2017, 11:18 PM | #5 |
Carpe manana
Re: Screws
Here's a reference pic if helpful: http://67-72chevytrucks.com/vboard/s...2&postcount=58
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-02-2017, 12:43 AM | #6 |
Re: Screws
Another reference. These are originals.
