09-02-2017, 08:14 PM | #1 |
LS3 - Manual to Auto?
I may have an opportunity to get a 2010 LS3 tied to its 6 speed manual transmission. It comes with everything from the donor car to do the swap.
Question is, what, if any, issues will I run into if I want to switch it to an automatic? Say a 4l80e. Thanks, |
09-02-2017, 09:17 PM | #2 |
Post Whore
Re: LS3 - Manual to Auto?
it can be done...but unless your getting a steal of a deal why not just buy a ls3 with a auto already behind it?..but..your gonna need everything from flex plate back plus a controller for trans and Im not sure what all else...
other than that a engine is a engine..you can put whatever behind it..I went from auto to nv4500 on my ls swap |
09-02-2017, 10:55 PM | #3 |
60-66 Nut
I have not done a swap such as this but my guess would be that you will need a complete wire harness and PCM for a LS3 with a 4L80E. You would likely get more answers if this was posted in the 'LSx Swaps' section.
09-03-2017, 06:47 AM | #4 |
Thanks Guys,
Little green in regards to the electronics and such. Might better say a LOT green! And yes....may have a pretty good deal on it. But it's not a good deal if I have to spend a lot on other components to get it done. |
09-03-2017, 06:49 AM | #5 |
It was recommended that I post this here:
I may have an opportunity to get a 2010 LS3 tied to its 6 speed manual transmission. It comes with everything from the donor car to do the swap. Question is, what, if any, issues will I run into if I want to switch it to an automatic? Say a 4l80e. Thanks, |
09-03-2017, 09:39 AM | #6 |
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
Threads merged
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-03-2017, 01:22 PM | #7 |
My apologies David.
09-04-2017, 11:41 AM | #8 |
It can be done, but I wouldn't recommend it for a novice (no disrespect intended). Buy it and resell it and use any money you make to purchase one with and auto transmission.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-04-2017, 11:53 AM | #9 |
Thanks Rob. Think I will hold off and do as you suggest. And, none taken..."iron sharpens iron..." Agreed!
