Drive shaft loop placement???
Its actually on my S10 not the 72'. I have ordered one and am wondering how far back from the trans tail should I put it?
I guess it really doesn't matter. I'd put it far enough back so that it does it's job; keeping your driveshaft from flinging all over creation if a u-joint let loose, but I wouldn't put it back so far that when your suspension compressed, the shaft hit on the housing. I'd probably go 2-3 feet past the end of the tranny; wherever you have a good spot for installation in that area. Just my $0.02 though....
CCRider
If you are going to any tracks where it will be inspected, it needs to be within 6 inches of the front u-joint.
http://home.fuse.net/fastmonte/DSSL4Gbodies.htm
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Fabricate till you "puke"
According to "dragstrip rules", the saftey loop should be no more than 6" from the center of the front u joint. On my longhorn, i run 2 loops for the 2 pc shaft....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Boy aren't I the dumba$$ on this thread....
Why is it 6"? Is it safer, better, etc? |
its all about the +6 inches
Just more effective.
Try spinnin 4 rear tars
You are supposed to put the loop near the tranny so that if your front u-joint says "no more" and breaks, then your drive shaft can't drop down and hit the track and drag/bend/grab/pogo your vehicle. If the rear one breaks, it's not as big a deal because it can just drag. Think of it this way... Take a rake (or something to the effect) and drag it behind you, then try to 'push' the rake. It is soooo much harder to push. Same idea with your driveshaft. You don't want it to grab a piece of track and launch the rear (or rip it out) of your vehicle.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
#8 | |
Wasn't pretty...even on a ford. |
