Old 09-03-2017, 12:00 PM   #1
60short
Revitalizing a 6T C10
60short's Avatar
1960 Clutch Slave Cylinder Bracket?
Good Morning All,
I have a 1960 Apache with a rebuilt 350, and what I was told was the stock 3 speed converted to shift on the floor - however I had the slave cylinder mounting bracket break on me and I was hoping somebody could tell me if this is a stock part? or something that was done as part of the floor shift conversion? It feels like Aluminium, so I am guessing its not original, but I am not sure where it came from either
IMG_4451 by Keith, on Flickr
IMG_4457 by Keith, on Flickr
Thanks,
Keith
60short is offline   Reply With Quote
Old 09-03-2017, 06:45 PM   #2
LVPhotos
LVPhotos's Avatar
Re: 1960 Clutch Slave Cylinder Bracket?
My 62 slave, passenger side.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-03-2017, 11:27 PM   #3
Captainfab
60-66 Nut
What you have there is not original to a '60-'62 truck. The original configuration is as shown in LVPhotos' post. The slave bolts directly to the bellhousing.
Old 09-04-2017, 12:01 AM   #4
60short
60short's Avatar
Ok, thanks for confirming guys ...
I don't have the parts to put this back to a column shift (though I would like to, so I will have to see if I can get it put back together...)
Old 09-04-2017, 12:50 PM   #5
61K10
61K10's Avatar
find the correct bell-housing and parts for your 3 on the tree. do you have a pic of the parts bolted to the trans or bell? looks like some bolts and washers can get you back on the road temp.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-04-2017, 05:15 PM   #6
LVPhotos
LVPhotos's Avatar
For the record and idea, I switched over to Hydraulic bearing because the clutch fork and clear the headers
Old 09-04-2017, 11:14 PM   #7
Captainfab
60-66 Nut
A 3 on the tree versus a floor shift has absolutely no bearing on the slave cylinder mounting. A pic of the bellhousing you have may help determine what you are working with.
Old 09-05-2017, 11:34 PM   #8
60short
60short's Avatar
I will try and snag a picture from underneath the truck tomorrow - its currently dead at work ... the slave cylinder was spaced out (using this bracket) to set the "throw" correctly.
I have no idea if it was correctly done or not, but it was functioning (at least for a while)
I dropped this bracket at the fab shop to see if they can re-create (a little more robustly), and I will get it running and then we can see about making it correct as well.
Thank you guys all for your help!
Old 03-24-2019, 03:29 PM   #9
Mister319
I just yanked the 235 out of my 60 and it had a bracket like the one being talked about,and I broke it but the v8 bellhousing that I bought looks like the slave bolts directly to it, like in LV's pic
Mister319 is offline   Reply With Quote
