Old 09-03-2017, 02:11 PM   #1
Chevytrevy
Front upper shock mount stud
Hello all,
I have a 1969 K10 with a small lift and 33s. I recently removed the old worn out rancho shocks on the front. The uppers were mounted with long bolts and bushings or "sleeves" jammed in the frame holes. I had to destroy the sleeves in order to get the shocks out. The new shocks did not come with hardware, so I ordered new studs for the top mounts.
For the life of me I cannot understand how to get these studs in without grinding off the rivets that hold on the upper shock mounts. Maybe I have the wrong studs? What am I missing here?
The studs have a thick threaded portion that goes through the frame, a fixed nut, smooth shoulder where shock goes and small threaded portion to go through shock mount. The thing won't fit in there and it's driving me nuts. Please help!
Chevytrevy is offline   Reply With Quote
Old 09-04-2017, 11:01 AM   #2
B. W.
B. W.'s Avatar
Re: Front upper shock mount stud
the stud is not the correct mount for the front shock. The front shock uses long bolts, both top & bottom. You will have to remove the tab from the frame if you want to use the stud. I don't believe the stud will be long enough, the top mount has a spacer that moves the shock away from the frame.
B. W. is offline   Reply With Quote
Old 09-04-2017, 12:13 PM   #3
Chevytrevy
Thanks for the reply. I'm assuming this stud must be for the rear then.
The hole in the frame is a larger diameter than the hole in the mounting tab, so I guess I will need some sort of special bolt. I haven't been able to find a stock replacement anywhere. Thanks again.
