Looking to add aftermarket Tach and need stock fuel gauge
Hello,
Looking to install an Autometer Tach in the Fuel Gauge spot to the right of my Speedo. I can't seem to find the small fuel gauge to replace it for any year past 1980. I've only found ones for 75-80 and 73-78 and I have a 1984 C10. Would either of those work? I'll be putting it where the clock is currently. Also, will the circuit board be okay just folded back so I can fit the tach? I'd make sure it couldn't short anything but wanted to know if there's anything I should look out for. Thanks in advance! Rob |
Re: Looking to add aftermarket Tach and need stock fuel gauge
I heard you can get a small tach and put it where the clock goes from Summit
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
#3 | |
![]() Join Date: Apr 2013
very nice...
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
Hey SCOTI. Did you have to cut the white cluster housing at all to get the tach in? Seems that the tachs wiring harness needs a hole to pass through on these? Ive wanted to do this for some time but have no idea how hard it is.
I would like to hear more about this. Do you have any Part Numbers for what you bought fuel/tach and how much modification needed to be done?
My kit came from here....
http://www.gmsports.com/content/1980...uge-conversion But the quad gauge set-up was crap. They had mis-matched the font for the 2 upper vs lower gauges. That part of the kit is still sitting in the box. That's when I just ordered the small gas gauge w/the correct font from LMC. There is a hole already in the plastic housing for the tach wire to slip through & I found another housing that had the fourth opening (clock housing vs a blank). Repo tachs available here.... http://www.lmctruck.com/NewParts/CC/CCRPT.htm or here http://www.classicparts.com/Dash-Par...ducts/349/30/0 The fuel gauge came from LMC but I just checked their catalog online & could no longer find it. I did a quick Google search & found them here.... http://www.classicparts.com/Dash-Par...ducts/349/16/0
for a easy lazy way of doing it, yeah you can stick it where the clock was. i just removed the clock and put it in its spot and tied off the wires kinda tight to hold it there. only pic i have of it
#9 | |
Thanks Scoti! That's exactly the info I needed. Much appreciated, that's the gauge I wanted to know about.
Rob Quote:
