Old 09-04-2017, 04:30 PM   #1
Drew3
Draining brake fluid?
If I plan on redoing my brakes , how do I completely drain the old system?
Drew3 is offline   Reply With Quote
Old 09-04-2017, 05:46 PM   #2
truckster
truckster's Avatar
Re: Draining brake fluid?
A vacuum bleeder will get almost all of it out. You'll have to remove the cylinders or calipers to get the remaining part.
Unless you need to replace cylinders, I would bleed everything you can out, and then refill and bleed until the fluid is nice and clear.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-04-2017, 05:52 PM   #3
HO455
Post Whore
HO455's Avatar
Can you define what you mean by "redoing"?
RIP Bob Parks.
Old 09-04-2017, 06:08 PM   #4
Drew3
New lines, booster, and master cylinder.
Old 09-04-2017, 06:26 PM   #5
HO455
Post Whore
HO455's Avatar
If it was me I would cut the hoses and remove the master cylinder cap and let it drain into drip pans over night. Then after removing the master cylinder the next day blow the lines out with air. If you can regulate the pressure 50 psi will make less of a mess than 125 psi. Then flush with brake clean and blow out again. The remaining fluid in the slaves will be flushed when you bleed the system.
RIP Bob Parks.
Old 09-04-2017, 06:34 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
If you remove the master cyl, the metal lines and the booster, all you have left is the wheel cylinders and calipers if it has discs...
You should replace the rubber lines as well...so, just cut the rubber lines off, near the wheel cylinders and place the end in a used water bottle, take the lid off of the master cylinder and let it drain over night.
Put some kitty litter around the area to catch any over flow...
Then just remove the master cylinder etc...make sure the bleeder nipples work ok first...
Note! Warning...There are numerous threads on here about incorrect booster / master cylinder combinations...please ensure whatever you buy matches up...
Finally...Suggest you look at the metal lines, these rust out on 2005 trucks,,,,so suggest you check em out real good...now is the time to do em ...
Stay safe...
AussieinNC is offline   Reply With Quote
