09-05-2017, 07:08 PM | #1 |
Motor mount bolts to motor
Does anyone know the correct size and length of bolts that go from the motor mounts to motor block? If so who has them?
09-05-2017, 07:10 PM | #2 |
Moderator
Re: Motor mount bolts to motor
Which engine ?
I-6 V6 V8 Small block V8 Big Block LS |
09-05-2017, 07:28 PM | #3 |
Im sorry it's a 350
09-05-2017, 07:44 PM | #4 |
Moderator
ARP
ARP 130-3102 $ 10.64 for a set of six with washers from www.Jegs.com Summit Racing would also have them If you need the two long ones, mount to chassis pods... ARP ARP 130-3105 Motor Mount Bolts Chevy V6/V8 $ 7.58 for both with washers and nuts Seeing its a 350 Chevy...your local auto parts shop may have them if you need em quick... |
09-05-2017, 11:09 PM | #5 |
Thank you very much Aussie.
09-08-2017, 01:51 AM | #6 |
size and length?
09-08-2017, 10:04 AM | #7 |
3/8 16 x 3/4" grade 5 I also used SAE flat washers as they have a closer tolerance in the holes
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
