![]() Join Date: Aug 2017
Lights going out
Hey All,
My high beams go out after being on for a few minutes, I can't really pinpoint whats causing it... It doesn't seem like a low voltage as I would think they would dim out first, maybe a heat issue with the wiring, but they wouldn't come back on after toggling the switch... I'm lost. 1960 C10 Short Step. Mike Last edited by TheBrewery; 09-05-2017 at 09:09 PM. Reason: Added Truck Info |
Re: Lights going out
i used something like this on my c10 solved the issue.
http://www.lmctruck.com/features/cc/ccc4l.htm |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Are your low beams still working? If so, it could be the dimmer switch.
Yeah, if I click it back to low beams they come back on.
I can also go right back to the highs and they work again for a few seconds then go out.
Mike 1960 C10 Short Step 235 w/ 3 on the tree 1999 Mazda Miata <- Track Car 2016 Chevrolet Colorado z71 2016 Chevrolet Traverse - Wifes Car 2014 Honda CBR500R <- Also A Dust Collector 2009 Suzuki GSXR600 <- Stolen ![]() |
Dimmer switch, or the wiring going to it. Look and see if any of the wires are melted.
Could also be the headlight switch itself. I've had both go out on me.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#6 | |
Are the complete kits from LMC worth a damn? Mike
I can't speak to the LMC kits, but I put an American AutoWire kit in my Suburban, and couldn't be happier with it.
-Brad (correction: I don't like the plastic light bulb sockets for the instrument cluster wiring harness. The next one I install will re-use the original metal sockets)
Are your head lights stock? No hds?
Not sure what you mean by hds, I just got the truck last month and am trying to sort out all the things the previous owner did and didn't do well.
Mike
