Old 09-07-2017, 09:39 AM   #1
Swedchevy67
Gauge wiring
I will use my original dashboard and wounder if my 22 circuit wiring kit 910-64022 from Speedway can be conected with this part?
Swedchevy67 is offline   Reply With Quote
Old 09-07-2017, 09:43 AM   #2
81turbota
Re: Gauge wiring
It can be wired up just fine. I'm not sure if your aftermarket kit will have all the sender wires but here's the diagram.
James
1971 Blazer 350/SM465/NP205
1966 Chevelle 468/TH400
2009 Corvette Z06 built LS7
81turbota is offline   Reply With Quote
Old 09-07-2017, 10:41 AM   #3
Swedchevy67
Re: Gauge wiring
That's good news!
Thank you for posting this diagram.
There is only one catch: my number 5 was empty.
Old 09-07-2017, 11:23 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Gauge wiring
Your number 5 is for the temperature sender wire for the three gauge lights dash, on the seven gauge dash it was moved to the number six for the temperature gauge and the number 5 was left empty.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-07-2017, 11:52 AM   #5
snipescastle2
snipescastle2's Avatar
Talking Re: Gauge wiring
I used that very same wiring harness when I built my 71'.
Just be sure to add a ground wire from the chassis to the metal tin
Of the gauge cluster and to the bottom terminal of the temperature gauge
(Ask me how I know) I kept thinking I over torqued the nuts on the back of the gauge where the circuit board attaches, causing the circuit traces to ground against the tin, turns out,
it just needed a dedicated ground wire to read correctly.
I actually used the original front light harness and the firewall connectors, and terminated them to the speedway harness. Everything was labeled so it was simple, just verified the factory wiring diagrams to the speedway schematic and was super easy.
Have a good one!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 09-07-2017, 12:07 PM   #6
81turbota
Re: Gauge wiring
Yep, additional ground is always a good idea. I added one to the tin of
My cluster and used a bullet connector for easy removal.
James
Old 09-07-2017, 01:17 PM   #7
Swedchevy67
Re: Gauge wiring
I don't follow "terminal of the temperature gauge".
It's hard to understand the technical language in English up here in northern Scandinavia.
Can't I use empty nr 5.
Old 09-07-2017, 03:05 PM   #8
toolboxchev
Re: Gauge wiring
Use the Electrical Section in the forum. VV is a great asset here and is always helping someone out!
Suprised this has not moved to the electric forum yet!
toolboxchev is offline   Reply With Quote
Old 09-08-2017, 03:00 AM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Gauge wiring
Don't feel bad I can't speak a darn word of Swedish.
Let me make it easy for you.
The no. 5 goes to a light socket for a warning light, the gauge dashes don't have a warning light.
They moved the sending unit wire to spot 6 and left 5 empty. See dashed red line on diagram.
The copper strip for spot 6 goes to the temperature gauge post (terminal).
The other post (terminal) gets 12 volts from the fuel gauge post .
Name:  Dash  Layout Final.jpg
the temperature gauge with the terminals (posts) labeled.
Name:  temp gauge.jpg
Känner mig inte dåligt Jag kan inte prata ett darnord av svenska.
Låt mig göra det enkelt för dig.
Nejet. 5 går till ett ljusuttag för ett varningsljus, har mätinstrumentet ingen varningslampa.
De flyttade sändningsenhetstråden till punkt 6 och lämnade 5 tomma. Se streckad röd linje på diagram.
Kopparremsan för punkt 6 går till temperaturmätarens stolpe (terminal).
Den andra posten (terminal) får 12 volt från bränslemätarens stolpe.
VetteVet
Old 09-08-2017, 07:26 AM   #10
Swedchevy67
Re: Gauge wiring
Not bad!
