Old 09-07-2017, 11:48 AM   #1
old and rusty
grease pencil markings
I was sanding down the firewall on my 67 pickup and found these markings under the original paint. The truck is ivory with blue interior. Anybody know what the "203" stands for?
old and rusty is offline   Reply With Quote
Old 09-07-2017, 05:31 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: grease pencil markings
"Ivory" is 528. The 203 could be an assembly line sequence number. Do you know which plant your truck was built in?
Some additional reading about grease pencil markings:
Factory Markings: http://67-72chevytrucks.com/vboard/s...ighlight=Linda
Need Help Deciphering Factory Grease Marks: http://67-72chevytrucks.com/vboard/s...ighlight=Linda
Show Us your Crayon Marks: http://67-72chevytrucks.com/vboard/s...ighlight=Linda
Factory Grease Pencil Marks: http://67-72chevytrucks.com/vboard/s...ighlight=Linda
Z Code Fremont Asssembly http://67-72chevytrucks.com/vboard/s...light=graffiti
Found my Build Sheet: http://67-72chevytrucks.com/vboard/s...light=graffiti
Numbers at top of firewall: http://67-72chevytrucks.com/vboard/s...d.php?t=545345
Help CC to the Nuthouse: http://67-72chevytrucks.com/vboard/s...ghlight=grease
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-07-2017, 05:42 PM   #3
Keith Seymore
Also - here is the generic info packet from the GM Heritage Center archive for '67.
I wasn't going to attach it but there is some really cool extraneous stuff in there, including rear suspension details and engine HP/torque curves.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
K
1979-1986
1986 - 2019
Old 09-07-2017, 06:22 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
Ya know, I think I spent a couple of hours -- 35 years ago -- with Simonize rubbing compound and a lot of elbow grease cleaning off the "Graffitti" on my '68 C/10's firewall. Who knew it would be important someday? Oh well.
Old 09-08-2017, 07:54 AM   #5
Keith Seymore
Could be worse. You could have thrown away the Mulroney window sticker plus some crpytic papers crumpled up in the seat cushion springs.
K
1979-1986
1986 - 2019
Old 09-08-2017, 11:15 AM   #6
old and rusty
yes, it was built in St. Louis
Old 09-08-2017, 12:32 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
I figured so. I've got a 72 cab from st Louis that has yellow markings all over it. Seems all the St. Louis trucks have lots of graffiti on them.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 09-08-2017, 01:03 PM   #8
TahoeK10
Junior Member
I have a 71 built at Fremont, it has the original paint on the cowl. Is it odd that there are no grease pencil marks on it? There is no evidence that they were removed either. It does have the marks left by the painters though.
TahoeK10 is offline   Reply With Quote
Old 09-08-2017, 01:37 PM   #9
Keith Seymore
Did you happen to read through any of these threads (especially the one related to Fremont)?
I don't think it is particularly unusual, since it could vary by shift and by operator. Depending on if the plant shut down for break or did "tag" relief there could be a half dozen different people doing the same job in one day.
K
1979-1986
1986 - 2019
Old 09-08-2017, 02:31 PM   #10
TahoeK10
Junior Member
Keith,
Thanks for the reply. I did read the other threads. While it seems that it was very inconsistent as to what was put on the firewall, I didn't see much mention as to having no marks.
Do you happen to know if the painters, when the left their "mark" on the firewall, did they ever leave a mark on the interior of the door?
Old 09-08-2017, 04:15 PM   #11
'68OrangeSunshine
K
Funny, you should mention that... Back in the late '70s, when I was cutting holes in the door panels for 5-1/2'' Jennsen stereo speakers -- I found a Build Sheet, in a hundred pieces, in the Passenger door. I saved the jigsaw puzzle in an envelope and kept it in my desk. I still have the same desk but now I can't find the puzzle. What I do remember was, it was a Fremont shortbed stepside truck, consigned to Felix Chevrolet, Los Angeles, and featured an L25 292, SM465, 7.00x17.5'' tires, WC Jr mirrors, and a deluxe ball-bearing ash tray, Fawn interior. No power anything, no radio [but a PO once had a VHF spike antenna thru the rooftop ] and 516 (Omaha) Orange.
I'm thinking it was part of a fleet order for Southern Pacific or CalTrans, who both liked orange.
Old 09-08-2017, 05:39 PM   #12
SIKKI-6
Here are the markings on my all original 71, firewall, inside fenders plus a few other spots, even the tag on the coil
SIKKI-6 is offline   Reply With Quote
Old 09-09-2017, 12:05 PM   #13
Keith Seymore
Keith,
Excellent.
It is inconsistent, because it was not an engineering requirement but more of a "help a brother out" between the guys in the assembly plant. No marks is certainly a possibility; my '65 GTO has no marking on the firewall (nor does my pickup, although it does have assembly sequence numbers on the hood, rad supt, grille and fenders).
The mark left by the Fremont painters was straight up "graffiti" and could have been punishable if found. As such they hid it where it would be covered up after the truck was assembled. I have never seen anything on the door, particularly where it would be quite visible.
K
1979-1986
1986 - 2019
