Old 09-07-2017, 12:55 PM   #1
davepl
davepl's Avatar
Shortening Drive By Wire cable
Friend of mine is installing an LS7 and trying to keep the cables as short as possible. The throttle pedal harness is about 5 feet longer than needed, so rather than coiling it up under the dash, he'd like to shorten it.
They're shielded and GM specifically says "DO NOT MODIFY" but I don't know if that's a liability precaution on their end or a genuine practical concern.
Online it sounds like they're hard to resolder, being high nickel content wires, so better to repin or crimp. I can't find any indications online of people having any problem or interference afterward.
The safe answer is "don't touch it" but I'd feel better if anyone knows WHY.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-07-2017, 03:08 PM   #2
toolboxchev
Re: Shortening Drive By Wire cable
If its would be dealing with cable length GM has it that long for a resistance issue. That of course has crossed your mind.
toolboxchev is offline   Reply With Quote
Old 09-07-2017, 03:49 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
I've seen the issues brought up about resistance before.. ..I've also seen several builds here where the harness was cut to shorten and/or lengthen wiring...
lm curious what the answer is as well..
Old 09-07-2017, 05:32 PM   #4
ls1nova71
ls1nova71's Avatar
I would say its more corporate CYA (cover your ass) than anything. . They don't want to be responsible for anything. I've never had any problems shortening any wires, and would think they would be similar to the LS3 I wired.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-07-2017, 05:43 PM   #5
mongocanfly
Post Whore
good to know ls1nova...I know I want to lengthen my main harness cause I want my ecm under the seat..Im gonna use psi harness and I was told they did custom lengths but when I contacted them they said no customs..
Old 09-07-2017, 06:16 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its possible, you just need to be cautious. The low voltage reference stuff is very sensitive to changes in resistance. So that needs to be taken into account when considering things like splices, connector types etc. I would not cut and solder in the DBW line anywhere. but shortening and repinning into a factory connector is pretty doable.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-11-2017, 10:42 AM   #7
indymachinist
^What he said.
If this is to be done, shortening and recrimping a factory terminal on the end is the way to go. No solder, no splices, no but connectors, etc.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-17-2017, 10:45 PM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Originally Posted by indymachinist View Post
^What he said.
Couldn't have said it any better... terminals are like probably .25 cents each..
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
