09-07-2017, 08:07 PM | #1 |
Battery cover
My battery cover is missing the bars that lock it in place. I would think I could make something work and make some replacement pieces. I know I can buy a new cover but I figured it wouldn't hurt to try, I'm sure I've got what I need to not spend anything but time.
Problem is that I can't seem to find any good pics. Can you guys show some pics with a good profile of what I need? Are they straight flat pieces or do they have a bend at the end for example. |
09-07-2017, 10:20 PM | #2 |
Re: Battery cover
I think I have one that is complete. Have to do some digging though or weed wacking to get to the other truck.
09-08-2017, 10:30 AM | #3 |
Re: Battery cover
Here ya go. Don't mind the grunge. The previous owner was trying to seal it I'm guessing. I haven't decided if I'm going to sand blast it or just order a replacement.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
09-08-2017, 11:24 AM | #4 |
Re: Battery cover
Thanks. That doesn't look to bad. I'll practice the bends on some clothes hanger wire then see if I have something thicker laying around.
12-31-2017, 05:14 PM | #5 |
Re: Battery cover
I've seen some pics if carpeted interiors... How do you guys cover the battery and still have access?
1950 Build |
11-02-2019, 05:23 PM | #6 |
Re: Battery cover
matt did you ever finish it? i am in the same boat. if i drive to az this month i either need to fix my cover or buy a new one. if i can just fix mine that would be awesome. either way i dont want the cover to keep trying to fly away.
My build a 49 5 window ls1 4l60e on a TCI chassis http://67-72chevytrucks.com/vboard/s...d.php?t=754926 My travel blog The Wong Winding Road-Adventures of The Chinese Cowboy https://thewongwindingroad.blogspot.com/ |
11-02-2019, 05:39 PM | #7 |
Re: Battery cover
You know I tested and played with it using an old wire hanger and cut and bent and it actually kinda worked. I meant to copy it with a thicker wire but I wound up using sealer to lock the door down and I cut into my inner fender for my battery instead.
1950 Build |
11-03-2019, 12:38 PM | #8 |
Re: Battery cover
I used to see that a lot along with Task force battery brackets on the firewall but still don't like the ugliness of it.
I should say that at one time I had my battery on a TF bracket on the firewall and the acid from the battey ruined a nice Weiand finned aluminum valve cover. True the voltage regulator wasn't working right and the alternator was overcharging the battery.
11-03-2019, 03:20 PM | #9 |
Re: Battery cover
I was going to mount to the firewall but I was worried about future heater and a/c plumbing
1950 Build |
11-04-2019, 08:42 AM | #10 |
Re: Battery cover
I used a drop down battery box mounted on the frame where the original was.
Something like this: https://www.classicparts.com/1947-72...SABEgI2ffD_BwE
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
11-04-2019, 02:48 PM | #11 |
Re: Battery cover
thicker wire is currently sitting in your front yard or on the corner of your road
after the election tomorrow, pull one of those wire loop signs out best freaking wire around, very stiff and holds it's shape very well plus there's an endless supply of it: election signs, real estate signs, college painters signs, will buy your house signs they're all fair game in my opinion
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-04-2019, 06:20 PM | #12 | |
Re: Battery cover
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
11-04-2019, 07:16 PM | #13 |
Re: Battery cover
If i don't like the party placing them i take em and use them as target holders on our range- work great and easy to attach targets. Also big satisfaction of putting holes in them is an added bonus.
11-09-2019, 10:12 AM | #14 |
Re: Battery cover
I'm going to the junk yard next week. I know where there is a 53 panel wagon if they have the cover I can pick it up.
11-09-2019, 03:53 PM | #15 |
Re: Battery cover
I just bought a classic industries one and its junk, the c channel is too long, and they used flat stock which i dont mind instead of the wire, problem is i can lock it down, and still lift the cover over an inch! This is with the new gasket
11-09-2019, 04:25 PM | #16 |
Re: Battery cover
I would think reproducing a good AD battery cover would be difficult. Originals are very heavy duty. Mine is original and would hate to have to replace it.
