Rear sway bar
I purchased a used rear sway bar from a board member for my 69 C-10. I can't figure how to install. Does anyone have a picture or drawing of the proper procedure? The truck has rear coil springs and is a short step side.
D.C. |
71 DELUX
There are numerous ways, depending on the bar. Probably should give more detals about it...or better yet, a picture.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
sway bar
The bar is in the sape of a long D, with flat ends that have holes in them. It came with two bolts about 10 inchese longs that have sleeves, and two U shape brackets that have rubber bushings inside. I assume the flat ends hang from the long bolts, but there is no place to attach the bar and U brackets. Have any of these attached to the shock mounts? I'll try for a picture.
D.C. |
71 DELUX
sway bar
sacto c-10
Thats it!! You got It!! I was trying to install to the rear of the axle. This makes much more sense now! Many thanks. DC
D.C. |
