09-08-2017, 08:12 PM | #1 |
Getting hood hinge springs back on.
Assuming I get my grill back on without too much trouble (see my other thread tonight on that), do you put the hood hinges on first and then put on the hinge springs or do you put the spring onto the hinges first and then put both onto the truck?
09-08-2017, 08:21 PM | #2 |
Re: Getting hood hinge springs back on.
I would mount hinge first then add the springs.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
09-08-2017, 09:09 PM | #3 |
With the hinges mounted I use an old hay hook to keep the fingers out of the way
09-09-2017, 01:44 AM | #4 |
I don't have a hay hook. I use a loop of 1'' nylon tubular webbing like climbers use, and make a 3' long sling. I hook one end of the sling on the spring hook end, put one foot on the front bumper and lean back, pulling on the spring and putting the spring onto the upper hinge notch.
09-09-2017, 04:01 PM | #5 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
09-09-2017, 04:03 PM | #6 |
Use cherry picker super easy
09-09-2017, 04:12 PM | #7 |
this is the way I have done this in the past, just be sure to use good zip ties. I set this up with bad ties just for the photo. I use my clamps in reverse.
09-09-2017, 05:02 PM | #8 |
Dude, if I was that much into high tech, I'd drive a late model car, not an ''old'' pickup.
09-09-2017, 05:04 PM | #9 |
Quick links would be safer. Other wise, good concept.
09-09-2017, 05:29 PM | #10 |
Great Idea!
Carabiner.
09-09-2017, 07:43 PM | #11 |
Great suggestions guys, thanks!
Dad and I made big progress today on the fenders, we may be ready for the hood in a day or so. |
09-09-2017, 08:05 PM | #12 |
Perfect. Just use the steel ones. The cheezy aluminum 'biners you get with the fake-Sigg water bottles will fail on you.
09-09-2017, 10:44 PM | #13 |
I made use of the steel posts I set to paint car parts, I mean for my wife's clothe's line, some chain and quick links, and a ratchet tie down or two.
Edit, I should mention I tied the spring up first, just in case (yikes).
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-09-2017 at 10:53 PM. |
09-10-2017, 12:09 AM | #14 |
I put the springs on before I put the hinges on the truck. I put the hinge in a vise and use a very large pair of 'truck' brake spring pliers. Works every time!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-10-2017, 08:45 AM | #15 |
That's funny...but we do love pictures!
1970 C10 Short Stepper with 71/72 front clip. |
09-10-2017, 04:54 PM | #16 | |
Please have a child, grandchild or great grandchild take video of you putting springs on the hinges. This could be fun to watch! Bill
09-10-2017, 07:14 PM | #17 | |
Besides, shooting a 5 minute instructional flick in 16mm, then developing it, and running it on a telecine to transcribe to VHS, then converting VHS to floppy disc, then floppy to whatever is next, for an uploadable format, is technologically unfeasable. Sorry. I've had this truck since I was 23. Printed directions... What's so difficult?
09-10-2017, 11:58 PM | #18 |
laying low
Some guys bolt the hinge to the fender then hook the spring at the back of the hinge and use an old fan belt to pull the spring forward, (extend it) far enough to hook on the front of the hinge. Back before high tech was a thing.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-11-2017, 01:47 AM | #19 |
Sounds familiar. I've also used my service web belt.
09-11-2017, 05:08 PM | #20 | |
09-11-2017, 09:36 PM | #21 | |
07-20-2019, 08:23 PM | #22 |
Thank you all Again for your posts.
Web sling and my little weight pulled it off and new ones back on.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
07-20-2019, 10:36 PM | #23 |
I just use a piece of rope about 4’ long . Hook the spring on the hinge ,double up the rope , run it thru the other end of the spring , pull it back with one hand and slip the hook in the slot on the inner fender bracket. Easy peezy
07-20-2019, 11:29 PM | #24 |
It really doesn't take that much pull to reload a hood spring, I use an old seat belt with the chrome male end with the hole in it to pull the spring.
just like this.. https://www.youtube.com/watch?v=bpspWtE26Iw
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
07-21-2019, 12:40 AM | #25 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
