Old 09-09-2017, 04:48 PM   #1
BS Stuff
56 truck heater hose routing - overheating
Trying to figure out why this truck gets hot and spits out before circulating / thermostat opens. Wondering if heater hose routing can make a difference?? Heater hose off manifold versus off water pump to special side of core ??? Drained block, all coolant flushed out and all hoses off / flushed. Was new engine and radiator 10 years ago but never put in or ran. Did not find hidden nests, etc.
56 Chevy Panel Truck
Targetmaster 350
Stock style 3 core radiator
Deluxe heater with new valve and recon core. Valve worked properly before installing.
195 Degree thermostat.
14" Electric fan with temp sensor kit - note - it kicked on fan right as spitting / puking started. Engine was ran long enough before capping so should have been no air in system.
Thanks !!
BS Stuff is offline   Reply With Quote
56 hose routing, heater hookup, overheating
